Tailgate strikers
Kelsda
New Jersey
Hi have a 1996 Yukon Gt anyone know where I can purchase the strikers for the tailgate. The plactic part is gone from one and other to follow. I believe the GM part # 15645314/striker is NLA any advice
Ever try the help section in the auto parts store? They always seem to have oddball parts.
I see some new ones on eBay for $40 shipped if you need them bad. Or maybe wrecking yard?
Kelsda
Kelsda
New Jersey
Thanks for all the responses, Fless I believe you are correct I have wrong number
east302
Mississippi
I'll be damned, I had no idea they were supposed to have a sleeve on them. Mine are long gone.
Do you mind measuring the outer diameter on that sleeve and letting me know what it is?
I've had a tailgate alignment issue for a while, wondering if the missing sleeves are the culprit. I might try slicing a piece of heater hose and slipping it over it to see if it helps snug it up.
HiHoeSilver
Away!
Chicago
I was gonna say measure it up and find a non threaded nylon spacer from McMaster Carr.
Kelsda
Kelsda
New Jersey
East302 I will measure tomorrow they are factory pressed on. I was thinking about diagonal cut on a piece of nylon or plastic sleeve this is my 4th 2 door all missing every time I go to a bone yard can’t find any right now I’m dying from stomach acid with pepto and Rolaids (thanksgiving dinner in-laws)
east302
Mississippi
Thanks, I appreciate it. Have you had any issue with the tailgate leaking?
I have a 1998 two-door and the top of the tailgate isn't seating with the liftglass, leaving a gap where water comes in.
These photos are not of my truck (they're from a 7 year old post on fullsizechevy) but show the exact problem that I'm having. The tailgate hinges do not have any slack in them (bushings) and I've adjusted the liftglass hinges to no avail. New GM weatherstripping (twice) didn't help, either.
It's as though the tailgate needs to come up about 1/4" on the passenger side, a little less on the driver side. When I saw your post about the striker sleeves, it made me think maybe it would help with the tailgate alignment.
Pictures are with the black exterior trim removed. Have you had this on any of your four?
Kelsda
Kelsda
New Jersey
The plastic piece is a 1/2 inch outside diameter and is not a tight fit on the inside sorry to say never had any leaks back there that I know of. Silly question how are your hinge pins on your tailgate? Did you try to seal the window to door with silicone just to see if that is your issue or how is that rubber seal on top of the glass it does divert water. Where is it wet on floor
east302
Mississippi
Thanks for taking the measurement for me.
The hinge pin bushings are original from what I can tell (still had factory paint overspray) and there's no movement in the tailgate. There's no rust (Mississippi) on the hinges or their welds to the body.
All three of the gaskets are new. The upper one is a slightly different design than the original. I've seen some where the flap rests on top of the glass in its closed position, but mine never stays and always folds back under.
A water hose test with the gasket in both positions yielded the same results: a leak where the tailgate gasket does not meet the bottom of the liftglass.
It's as though the right side of the tailgate needs to come up about 1/4" so that the tailgate gasket meets the underside of the lift glass. To make that happen, I'd have to bend the hinges somehow. I've been hesitant to do that.
No amount of monkeying around with the liftglass hinges at the top would make it work, either.
I had done a post on the problem maybe a year ago. Although two or three other people had the exact issue, none of us could figure it out.
Maybe ours were all built by the same defective robot.
Kelsda
Kelsda
New Jersey
Found a few tailgate strikers from a couple of 94 trucks, these are the same length all metal originally I measured nylon bushing I said half inch ng it’s 9/16 found a few more with nylon on them 1994 tailgate strikers are 1/2 inch I don’t know why the change but I’m going to try them out. Any luck with water issue ? Do you think it is possible to remove tailgate carefully remove hinge and weld a shim. Might take some time try a few different shims 1/32 1/16 and so on maybe both sides to keep body lines consistent
east302
Mississippi
Thanks for the updated measurement. I did try slicing a piece of heater hose over it. I think it was 3/8” but don’t recall the thickness. Anyways, it was too tight—the door wouldn’t even shut.
I think it has to be an alignment issue with the top glass but I never could figure out how to make it cooperate.
I briefly considered taking the tailgate off and seeing what I could do with it. It has a spring-loaded torsion bar in it, so I was hesitant to pull that joker out. The hinges are welded to the body and tailgate, so there’s no easy adjustment there.
I did contact the previous owner about it. He couldn’t say how long it had been leaking, but did remember having the tailgate glass replaced several years ago. If I had to guess, that’s when it started.
To keep it dry, I added some RTV under the tailgate gasket to raise it up about 1/8” so that it meets the bottom of the lift glass. It’s dry, but still bugs me.
Kelsda
Kelsda
New Jersey
Try dorman 38427 all metal from looks of picks replaces liftgate on 94 blazer
bowtieman55
Elizabeth City, NC
View media item 27419 View media item 27420
The original style with the plastic sleeve is no longer available, so we have to use the same ones that are used for our front doors. They are the same thickness as the originals, when new, and work perfect as a replacement. Since they are all steel, they won't deteriorate like the plastic sleeves do. I installed a couple of the GM replacements on my '97 last night.
The GM number is 15013147 and the Dorman number is 38428.
east302
Mississippi
Thanks for the update. So the Dorman (which doesn’t have a sleeve) is the same diameter as the stock one with the sleeve?
96-2D-Hoe
Old thread but WTH. I used a piece of 1/2 (I think) fuel pipe and wrapped it in black electrical tape. Lasts about a year or so before it falls off. Closes a bit tight but doesn't rattle. Might spring for some Dorman's
bowtieman55
Elizabeth City, NC
The GM number is 15013147 and the Dorman number is 38428. I like not having to "make" something work.
JasonW4141
