2006 GMC Yukon XL
Woodblocker55
Can you put 2007 calipers and rotors .on 2006 ? Long as you have 17 inch wheels ? Will it screw up the stabletrack ?
Sent from my LGL84VL using Tapatalk
HiHoeSilver
Away!
Chicago
Yes. Usually just the front. Use 2013 when you search so you get the newest casting number with the retaining clips. The rotors will be ~1" bigger than what you have now. It will not affect stabilitrac.
It's been the consensus that the rear is already better on the nbs and not worth changing, but I remember this recently coming into question.
If you want more info search for threads on the nnbs brake upgrade.
Woodblocker55
Woodblocker55
That's pretty awesome . Because I'm going to be doing some serious towing . Does 2013 have 2 piston calipers ? And do they bolt right on ? [emoji15] I'm kinda semi metallic pad kinda guy . That be the clincher I would need .. I looked guy that owned it before me put $50 ceramic pads. And he went thru like 3 sets of pads and rotors in 55,000 miles . I'm only guessing but I think if he would of got right GM pads he only have gone thru 1 set .. I have HD towning package . Says $94 a set 2 for pads .
7200 lbs . I will be doing some searching thanks for the tip. [emoji106]
HiHoeSilver
Away!
Chicago
7200 lbs . I will doing some searching thanks for the tip. [emoji106]
Yes, the 2007-2014 have the two pistons. You will need the calipers with the brackets, rotors, and pads. A lot of guys change the rubber lines to braided SS at the same time. There are line kits from stop tech and Goodridge, among others.
I said use 2013 just because they changed castings somewhere in 2007. As long as you use 2008 or later, you'll get the newer version, I believe. I used 2013 just to be safe.
Candielaine
