Came home tonight and was backing into my driveway when I decided to park it and have my wife sit in the driver's seat and push the brake pedal so I could check out the brightness of the new LED bulbs I installed during the day. She yells something about the pedal going to the floor. Sure enough there is no line pressure, therefore no brakes, I have a dash warning light on, and fluid dripping out just inside the driver's side front tire. This could have happened 5 minutes earlier in traffic.
I found the front hose, of the two hose that run from the master cylinder down to the proportioning valve, was leaking badly. It appears to be similar to a brake hose that would run to a caliper and has a stainless steel mesh armor. Right where it turns away from the fender well and heads to the valve it leaks.
Maybe I am searching using the wrong terms but I can't find any part numbers or diagrams for these hoses. Does anybody know if these are available?
Also, this is a 2006, how tough are these to bleed by yourself?
I have no problems bleeding when it involves a downstream part like a caliper or wheel cylinder but I am worried about air at the beginning of a ABS system.
