2 Issues After Leveling Kit (04 Tahoe)
Sausey
2004 Tahoe LT AWD.
So about 2 months ago, I decided in order to clear some larger tires, I'd raise my Tahoe a bit. I went with some Discoverer AT3s 285/70R17. I also installed:
1. Rough Country leveling keys
2. Bilstein 5100 shocks all around
3. Stiffer Bilstein coil springs, as my Tahoe was originally equipped with the Premium Smooth Ride package and self-leveling shocks
4. 1.5 inch coil spring spacers
I then went straight to an allignment shop. Since then, I've had 2 major issues.
Firstly, when accelerating, the steering is dangerously unstable. Under light acceleration, the truck wants to wander to the left, forcing me to turn the wheel almost 45° to the right to keep it going straight. Under heavier acceleration, the truck snaps from side to side, almost like I was driving on ice even when the pavement is bone dry. It's impossible to stay in my lane when trying to pass or merge.
Secondly, my traction control is on the fritz. Almost everytime I start forward from a stop sign or red light, "Traction Active" will appear on my dash and cut my throttle. This also happens when going around turns, but usually only when starting from a stop. I'm not mashing the throttle at every stoplight either, even at a crawl traction control wants to kick in.
I've also noticed a lot of uneven wear on the outer edges of my front tires, way beyond what you'd expect to see after only 2 months or so.
So what's going on? I figure the traction control issue could just be that the computer is programmed with the factory tire size, but the steering issue has been making the truck almost un-driveable. Is this just a matter of the allignment shop not properly alligning the tires? Would a steering stablizer remedy this? (I'm planning on installing one anyway.) Did I not install these parts correctly, or is this an issue with the suspension that was brought to light when I upsized my tires?
Any help is hugely appreciated.
BourbonNcigars
You said you had it aligned. Do you happen to have a readout or numbers from the shop?
Sausey
Sausey
I don't, no. But I made an appointment a week ago to have a different shop take a look at it. It's due in there tomorrow morning, what should I ask them for?
BourbonNcigars
Camber, Caster, and Toe. You need numbers so you know exactly where you are.
How does it ride after the keys, shocks, and springs? I know that's a subjective "non-numbers" based question, but it can matter.
Sausey
Sausey
I live in PA, even the nicest roads have horrendous potholes. When I'm on a really bumpy road, the wheel has a tendency to jutter back an forth a bit, but I figured this was just because of the larger tires. It's really only when I'm giving it gas that the steering wheel wants to fight me. Doesn't seem overly stiff or soft, it takes bumps pretty smoothly and it's not rattling my teeth or anything.
Sausey
Sausey
I noticed that the front and will hop up for a split second, but only if you absolutely floor it.
BourbonNcigars
Under normal acceleration, does the traction control light come on? And did the traction light only come on after the mods? I recall my 2002 Z71 having inherently flighty steering...
Sausey
Sausey
The traction control only comes on from a stop. If you're cruising at 40mph and you accelerate to 60mph the light won't come on. This traction control problem started after the mods, namely the tires.
BourbonNcigars
Since I no longer have the same body style Tahoe that you do, I'm going off memory and knowledge of other vehicles so bear with me.
Generally, a steering issue is related to caster. Namely, lower caster. That can happen when you lift the front end, which can also set off traction control sensors (in a Jeep, a steering wheel that's not centered can do it too). Again, I'm assuming. I'm not terribly familiar with the GMT800 steering setup and geometry. I really want someone with the same ride as you to chime in.
Sausey
Sausey
Picked the Hoe up from the shop yesterday, the alignment was definitely out. Control arm adjustment bolts were seized. Had them replaced and I the shop was able to get the wheels properly aligned. Also had the driver's side wheel bearing replaced as well as the ABS sensor (evidently this was what was causing my issues with the traction and stability control.) Hopefully all my issues are solved.
Merc1973
Maryland
In my experience with lifting jeeps. Whenever you get alignment issues with accelerating/decelerating the culprit is usually rear control arm bushings. Think about it. When you accelerate, your increasing torsion on the rear axle. and its going to want to twist if the bushings are shot. Since You lifted the truck, I doubt you loosened the rear or front control arm bolts priot to lift kit install and then to re-torque them at your new ride height, right?
ALWAYS whenever you install new control arms front or rear or a lift kit, you ONLY torque to spec the control arm bolt when you're at ride height. Otherwise if torquing them on a lift, you will destroy the bushings quickly since the bushings will twist when you lower the truck back down and then the constant up twisting of daily driving, your rubber bushings will be shredded.
VDV18
Not sure how long after you were at the 1st shop for the alignment that you started having issues, but I would have chat with those fellas.
briannorris
