TPMS sensors
Looking at buying new take off rims and tires for my ‘05 Tahoe. They come ready to Bolton, including lug nuts. These would be from a 2018. Would the 2018, TPMSsensors work? Or would I have to install sensors for an ‘05? Or maybe programs something?
Agreed they won’t work. I believe they change with every platform ie 03-06, 07-14 etc.
depends:
check your glove box for rpo codes
xl7 is 315mhz
xl8 is 433mhz
then you will need to know what the mhz was of the truck the wheels came off of to know if they will work with your truck or not
the 2018's no longer a have a rpo list in the glove box so you will have to either scan the QR code or look at the build sheet
if the mhz do not match they wont work, if they match they should work
depends:
xl7 is 315mhz
xl8 is 433mhz
Hmmm my 08 Silverado has neither of those RPO’s. I just looked up the info on the new ones I just bought and it says they’re 315 MHz and the application chart says 08-18 Tahoe’s Silverados etc.
maybe its in your build sheet
The RPO on my '04 appears to be UJ6 (Low Tire Press Indicator), if I'm reading that right. 315 MHz.
uj6 I believe just means you have tpms, I think most of the older trucks are mostly 315mhz though anyway it probably would show in your build sheet the freq
also I think the only difference in a 315mhz sensor from 1999 versus one from 2108 is if it fits in the wheel or not, hense different part numbers and they could be strapped to the wheel if it wont fit anyway. but i could be wrong but iv'e never read anything that says different, a tpms sensor syncs up and has a serial number that registers to the receiver that way it's not picking up random sensors from other cars driving on the road next to you. most are either 315mhz or 433mhz with the later being used mostly in Europe
on the tpms 24/7 website (on the Tahoe for instance) they only sell them for 2004 and up (thru 2018) and they all use the same part number for the 315mhz
So the op should be ok to use the 2018 ones in his 2005?
HiHoeSilver
Away!
Chicago
This is definitely wrong. Nbs needs nbs. I'm not sure if the NNBS and k2 are interchangeable.
per rockauto there is some different oem part numbers but it still shows specification uj6 for both a 2004 and a 2008
I am no expert but it's wierd that the uj6/xl7 are both 315mhz and I only see the difference being how it fits and/or how it is programmed the standard brand require no programming and are clonable, others may require programming with a tool.
2004 acdelco 13598771 (uj6), 2008 15136883 (uj6), 2017 13516164 315mhz xl7
2004 denso 5502403 315mhz (clamp in), 2008 denso 5502400 315mhz snap in
2004 standard tpm43a 315mhz, 2008 standard tpm45a 315mhz, 2017 tpm207 314.9mhz
HiHoeSilver
Away!
Chicago
There's a thread or two about all this. My wheels are from a 2015, so I did the research before. Had to change them to work with my 06.
I see different parts for up to 2006 on Rockauto and then from 07-up they changed. 07-18 look to be the same parts. All have the same frequency but something must have changed in 07.
I don't remember. Something about the truck not being able to talk to them, iirc. I can search some more this evening. It's in the forum somewhere.
ok, no biggie I was just curious I thought they were pretty standard across the board
Conedaddy
