Yukon Denali cluster interchange
442scotty
Does anyone know if a 2006 Yukon Denali cluster will work in a 2005 Yukon Denali?
I have to repair my 05 Cluster but I have an 06 cluster sitting around that I can send in (Dr speedometer) allowing me to keep driving in the meantime
you should be able to, real easy to find out just pull your existing cluster out and look at the harness for that one and the one you have as a spare, if the harness is the same it will work, some years are different but only because they changed the harness
442scotty
True enough . In the time I spent making this thread I could have pulled it out
adventurenali92
Big Bear Lake, ca
It should work. Worked the other way around for my truck. I have a cluster out of a 2005 Escalade in my 2006 Denali xl and works just fine.
CKendrick
