Adjustable thermostat? Are you talking about the one in the thermostat housing (neck)?
I'd love some pictures.
I bought it from Autozone. It's basically a probe that goes in between the radiator fins and can be adjusted to turn on the fans at just about any temp. IIRC, it was only $17 and has been working perfect since I put it in.
I just realized I don't have any pics of the install. I'll try to get some up for you this weekend.
Don't have to program the pcm. The aftermarket thermostat controls the fans. Another option is programming the pcm to turn on the fan control and use that instead of the aftermarket thermostat.
that is what I am wanting too dec322 an increase in mileage would be great
I'm looking for electric fans that when "all said and done installed" look like factory but would like to see any successful install pics as well!!
Ok. That makes sense. How long have you been running your setup? How accurate is the aftermarket thermostat?
I'm a little worried that the thermostat might give out and the fans won't come on...then I overheat and then I blow a head gasket. My wife drives the yukon and she will never check gauges to make sure everything is functioning.
Did you notice an increase in MPG?
I also saw something about a S&B Intake. Where do you buy one?
Jenna is 100% right, We say 20hp two guys garage says 23 on a mustang dyno here is a link http://www.volant.com/commviewer.asp in house I use a superflow, granitelli uses a 4 wheel drive mustang, Wide open throttle uses a mustang, Van gordon uses a superflow, Dyno Jet has a 10% power curve which the autodyne 90 software can factor in for the customers that use more than one dyno shop, Fact is Jenna, Baseline is Baseline and max is max if you use the same dyno for baseline and max both runs will show the same hp gain no matter what brand you use. Careful with your words if you want to throw everyone under the bus
I am well aware that there are many ways to bump the numbers on a dyno, my comment was not regarding that you cannot change the numbers by altering the test. It was stated that everyone uses a dyno jet and plays with the numbers. If I were a customer that had no idea how this indrustry works and I were to read a post like black bears if would make me think twice about ordering aftermarket parts for my truck. K&N is one of the biggest companys around they use a dynojet but there numbers are dynojet stock and dynojet after but the software should factor in the % difference for wrhp. My dyno can pull up Superflow, mustang, and dynojet numbers. Intakes make little power tell 3200 rpm on up so most test start at 3000 so unless you have an exhaust there is little need to run the test from 700 to 6000 theres to must data to go through.
