diffrence between 4" and 6"
tofst4uvette
I know 2" ha ha. seriously I have my truck in the shop and I need to decide between 4" and 6" guy at the shop say 6" is fine. highway driving will still be able to go 65 70 mph. 4" lift i can go a little faster, better gas milage.
I am having a hard time deciding any advice would be good, this is not a daly driver but I do take it on long road trips and in the woods to hunting spots.
its 97 tahoe 4 door
thanks Johnny
99COOP
Retired
Chicago, IL
6" you will be plenty happy with that. Get a 4" and you WILL want to go bigger. Plus most kits are near the same prices for their 4 and 6" kits. You wont notice negative handling characteristics or bad gas mileage between the 4 and 6 either.
knotty
its 97 tahoe 4 door
thanks Johnny
i would go 6 if it was mine.... all you would have to do is regear if your worried about " faster & better milage"
bowtiefreak
No Quarter
Near Philly
Lifting has nothing to do with speed and power of a truck....tire size and weight will make it sluggish with out a regear. I know guys running around on 12" lifts 80+ on the highway.
Get a 6" lift, trust us all because you will regret a 4" kit with in a month if not sooner. My truck is pushing 7+ plus and to me it looks like stock height.
T
tofst4uvette
o.k. I have more people saying 6 than 4, i had a few try and talk me out of the 6. when I go for the 6 is thier any down side to having blocks in the back compared to springs, do the blocks u-bolt need re-tightening every couple thousand miles.
do I need dual shock set up or is single fine, here in jersey whats the law for tires sticking out to get threw inspection?
3 kits I`m looking at are, pro comp,fab tech, sky jacker, tough country,
thanks Johnny
MOBmentality
Has a $25,000 Punch
i had 10 inches on mine and i drove it jax to orlando at 75 all the time and never had too much of an issue.. 4 inches.. is soft.. are you soft? cause i mean.. i didnt know soft ass dudes lifted their trucks? i mean i thought it was like.. something MEN did.. .i mean.. OLD JOHNNY woulda done 6.. have you really changed that much? arent .. you.. a .. man?
Hope i helped :D
A block actually rides BETTER IMO.. a spring is a stiffer taller spring.. where as a block.. is gonna ride just like the stock spring did.. since.. its still the stock spring...
and i ran dual shocks front and mono rear
99COOP
Retired
Chicago, IL
Yea if you bother w/ a lift go big. You dont need to have dual shock hoops, but they are nice. Blocks are not bad and the most common rear lift that is chosen, however after people install their lifts most will change to full springs. Blocks create alot of axle wrap and give a less stable ride characteristic then having springs. However you can always just run a 2" block, shackle flip kit and a zero rate and have a pretty much stock feeling setup. I would avoid alot of the lifts you have chosen as possibilities, however pro comp is your best choice from the selection.
cmcarr85
SAS.... Once you do the 6 inch your gonna want to go higher trust me...
rucr8z2
Saluda,Va.
6" and both my old 2dr on 36's and my new 4dr would do everybit of a 80-90mph easy and not fell unsteady at all but make sure you replace worn suspension,steering components while the lift is being put on....
IRQVET
2 Door Owners Club
Tallahassee, FL.
Depends if this rig is your daily driver?
Any lift over 3-4 inches for a daily driver is excessive unless your commute is short enough where it won't matter IMO. The hard issue to argue is how awesome a 6 inch lift looks once someone does it, lol.
MUDDER TRUCKER
port huron,mi
i have 9 inches /6susp/3body. 38s i have got it to 95 on highway for two hours it sucked a tank of gas in 119 miles. but i love the lift and the way it looks. if u were to do the speed limit or close to it haha and get the 6inch it would be nice! go with the 6!!!
hapyspaz
Austin
Avoid Fab-Tech, they are going out of business.
Avoid Tough Country, its more or less the "cheap" lift.
Pro-Comp is pretty good, if I remember correctly it requires more modifications than most.
I have installed many SkyJacker lifts, including my own, and for me they have always been the best on ride quality.
bowtiefreak
No Quarter
Near Philly
extreme suspensions = tough. Not the easiest to install but has a GREAT reputation for the strength.
Black Bear
Dallas, TX
well i have the same question 4 or 6. and pretty much what every one has told me and after reading this thread. i'm going for a 6 inch lift myself.
bowtiefreak
No Quarter
Near Philly
It is the Cepek kit.....I haz one on the tahoe. a true 6.5" differential drop....more than all other 6" kits that are more like 5.125" drop or so.
sparg93
Expedition Tahoe
NJ
Did you install that or have a shop do it? If you used a shop, what did it end up running you for the install?
This is more of a technical question, but I'm going to convert my 1/2t suspension parts to 3/4t, any idea if the Dick Cepek suspension kit designed for a Tahoe would still work or should I look into the 2500 suburban kit?
Unfortunately I don't have a lift and for that install, it really looks like you need one and more experience then I have.
bowtiefreak
No Quarter
Near Philly
I worked with a couple guys on the tahoe since I had no idea about anythign at the time. It was more of a pain in the ass than the RCX kit, the directions sucks and teh fit was ok. The kit itself is very strong but again the instructions blew. Thankfully the guys had done IFS lifts and had the general idea. The RCX kit was much easier, very straight forward.
As for teh 3/4 ton, no idea. Sorry
vsaravia
