New guy - Picked up 03 Tahoe Z71
Cinycreech
Whats going on everyone!
Quick info on what I snagged..
2003 Chevy Tahoe Z71
225k 1 owner guy was 75 years old bought it when he retired
Drives and Runs smooth
Honestly, I am not sure I could have found a cleaner truck. Looks like the passenger and back seats have never been used, everything works even the TV. Exterior is perfect no dents, dings or major scratches.
Now to the fun stuff..
Issues with the truck I would like some recommendations if possible..
Front and Rear Bumpers surface rust - Do I spend the coin and replace them? Try and save them? Or paint them?
Instrument cluster does not work? Any recommendations on brands? Pull and Pay?
GetFileAttachment
GetFileAttachment
Scottydoggs
NJ
for a retired guy he sure put the miles on it, nice to see he cared for it. looks damn good for th emiles.
if you mean the cluster dont work like all the gauges are out it might need a rebuild. theres guys on ebay who rebuild them, they also install all new lights.
if the radio is also out it could just be a fuse, iirc they are on the same fuse.
ive seen new back chrome bumpers for like 100 bucks on ebay too. no idea how long they last. you know start to rust them selves.
not sure on the fronts, never looked for one.
PNWMuseumman
Bow Ties Are Cool
PNW
Welcome from the PNW! The truck looks great! I've always loved that color
C
Cinycreech
I’m pretty sure they commutes down to Florida a handful of times a year from Ohio.
He said he took it to 2 different shops and both said just to replace the cluster. So figured I’d just replace it.
I’ve done some research looks like some aluminum foil and water, wool and coke seems to work. Going to try it this weekend see what happens.
Feels kinda tight in the front an in the steering wheel when only turning right. Wonder if it’s a tie rod
Scottydoggs
NJ
the tight steering sounds a lot like a bad steering box. tie rods cause a clunk and or a wandering front end.
miles are stored in the cluster, so make sure your able to transfer the miles over to the new or used one.
the re builders on ebay can do the miles swap. or a dealership im sure. ( at what cost tho?) you need to sign and send in a mileage disclaimer form for legal reasons.
C
Cinycreech
Cool Thanks for the info I will have to do a little more research.
Whats some standard maintenance you guys would preform after picking up a high mileage used Tahoe? Anything in particular I should just go ahead an take care of?
Scottydoggs
NJ
id start with a tune up and changing all fluids. coolant to diffs and t case, if the trans fluid is dark a pan drop and filter is as far as id go, changing all the fluid, aka a flush could kill it.
being you already have a front end issue you'll want to have or inspect the front end yourself. make sure all moving parts are still tight. end links like to break and cause a clunk or rattle sometimes.
and check all 4 brakes, replace if needed.
i bought a set of R1 e line drilled and slotted pads with their scorched pads due to my brakes needed to be done super bad when i got mine.
looks like the last owner was a pad slapper, with 121,000 on it these have to be factory rotors. all 4 rotors were pooched like this one. even got a curved pad lol
Erickk120
Like someone said above, there is a guy on eBay that does the cluster for around 100 to 150 depends on how bad it is, He did mine about 1.5 years ago my cluster was totally dead, only the gauges worked but no lights. I chose all blue LED's it looks awesome. Bumpers can be had for around 100 dollars on amazon too, I replaced my painted one and I didn't feel like paying 230 for a painted one so I just got a chromed one. Been fine for about 1.8 years too. I do agree, do all the fluids and if possible get the merchant pump saver for the transfer case before you change the fluid so that you don't ever get the pump rub problem.
C
Cinycreech
Can you throw up a link up of the bumpers? I have a buddy that actually paints an can take hook it up!
Im hearing a little constant squeak, pretty positive it’s brakes. I’m going to order all brakes an rotors an throw them on. Any recommendations out there?
Picture after cleaning up a little. Need to figure something out with the Dull plastic trim.
Welcome. What dull plastic are you referring to? If it's the black exterior stuff I've had great success with Krylon Fusion or Super Bond in satin. Both have held up well.
Quentin Smith
My friend, when you get your bumpers painted or fixed, just make sure to spray rust converter or a POR 15 or SOMETHING on the backside of them. As far as I can see Chevy left them mostly RAW and then we wonder why they all rust...
C
Cinycreech
Will do! Honestly there are a couple places local I can find some Chrome no rust bumpers - Will probably just go with that.
Also, I messed with the cluster an it randomly started working. Old man was slightly off on how many miles the truck had.. 20k off lol. He stated the truck had around 225k it has 204k
X-ray Nerd
