LED vs HID headlight upgrade?
Vanquish Auto
202 Wallace Ave N Unit 12 Lehigh Acres FL 33971
Syniba
Buffalo NY
Use coupon code saveme20%. If it doesn’t work let me know so I can fix it
So for a 2018 Tahoe LT with halos, I won't need a relay for your HID kit?
edit: relay, not ballast.
Syniba
Buffalo NY
That’s correct!
Thanks, I decided to order anyway after my post as I read elsewhere you didn't need a relay. Everything went great except the clips into the wire inside the headlight don't snap in.
Vanquish Auto
Did I send you separate connectors to get it fixed? I had a customer with this problem not long ago.
Tultruk
