08 Tahoe Front Fender Replacement
tiktok4321
I busted up my front passenger fender on my Tahoe last night. Good news seems like replacements are pretty inexpensive, though I think OEM was aluminum and I can only buy steel. No biggie. Adds a few pounds.
I can't find ANY online video on how to remove and replace, though. The 07 seems simple, but I know I'm not that lucky.
I also can't find one painted. Should I pre paint or install and blend? It's white, so I don't know how that would affect it, but it makes the cost start exponentially climbing.
Any help would be great. Thanks.
Sent from my SAMSUNG-SM-N920A using Tapatalk
I have a fender in my shop to replace my wrinkled driver's side fender. I'll take some pics of it's mounting points, hopefully those will help.
I don't believe the OEM fenders were ever aluminum. The replacement fender I have is an OEM part and it's steel. I got mine from a guy that was parting out an Avalanche. It's the same color as my Tahoe and is dent-free, but the paint has lots of chips and scratches which is why I haven't swapped it on yet. Have you searched your local salvage yards or Craigslist for someone parting out a Tahoe, Suburban or Avalanche of your Tahoe's color?
tiktok4321
tiktok4321
Thanks for the info. I'll do some looking before committing. It's the install that intimidates me most.
fenders are usually pretty easy, just have to look it over, you can see from the replacement where all the bolt holes are and usually you will need to unclip the bumper cover, there will be a couple bolts in the doorjam and one under the door hinge area the rest are along the top of the edge of the engine compartment/hood and wheel well. r&r there usually not a perfect fit so you may have to push or pull a bit to get it aligned right.
tiktok4321
tiktok4321
Alrighty then. Did the swap yesterday. Learned a lot. Took me about 4 hours, but I think if the sequence is right, it can be done in 2. Here's a step by step to be most efficient.
1. Remove the hood. Unclip strut, remove 4 13mm bolts that attach hinge to hood. Pop out trim that surrounds hood hinge. A two man job!!
2. Remove fender liner. Don't need to remove wheel. There may be a harness plasti-clipped to it from the back side.
3. Remove headlight. Loosen two bolts between fender and bumper cover, pull out bumper cover, remove one bolt attaching bumper cover to frame from underneath (it's the one that faces forward, not up or down).
4. Remove bracket attached to stud located under c-bracket connecting fender to firewall. This should be two 10mm nuts
5. Remove two 10mm bolts from under air intake. To get to them, just lift up the air intake and pop out plasti-clips.
6. Remove all the 13mm bolts. One from underneath by door (there is a 10mm bolt that hold a small piece of trim to the sidestep that makes it easier to remove the fender in the end), two in door jamb, three around the hood hinge, two in top middle, three behind headlight. Then the whole thing just pops out!
Don't forget to transfer the hood hinge to new fender.
I may have missed a couple things, so I may edit this as I review my video...
Thank you for posting this! I'll refer to it when I swap mine.
ramchol76
@tiktok4321 thanks for the summary, do you have the video published anywhere? I need to remove fender to fix a water intrusion behind.
tiktok4321
tiktok4321
Sorry. That was two years ago. I never had enough good footage to compile into a how to. Sorry about that.
If you go over the steps I listed above looking at the vehicle before starting, I think you'll get the gist of it. The most important aspect is the order of things to keep from wasting too much time.
Good luck!
ramchol76
thanks @tiktok4321
I am thinking if I can make couple of tweaks to reduce alignment issues. 1) removing the hinge bolts of hood and having hood support instead of removing hood fully 2) removing the fender liner partially i.e. clips and bolts connected to fender and leaving the rest in place.
can you please validate if these tweaks are ok?
tiktok4321
tiktok4321
You may be able to do that. My concern with #1 is that you could potentially twist the hood bracket. If you can prop up the hood securely, that's ok, not just worried it could move when working on the rest.
signguy62
NJ
Reviving old thread....
What body panels (07-14) are interchangeable across the various platforms.
Will Silverado or Avalanche fenders/hoods/bumper covers, fit Tahoes?
Thanks!
Thanks!
Tahoe, Avalanche and Suburban are direct swaps. Silverado, Sierra and Escalade, etc. can be swapped if you swap the core supports. Then there's the wiring and lighting arrangement mismatches. All, other than Tahoe, Suburban and Avalanche, have to have their respective hoods, grilles, etc. No mixing of these parts.
spectol
