guy from norcal
- Joined
- Jul 15, 2012
- Posts
- 703
- Reaction score
- 540
GM loves to cut corners.
Ridiculous... at least u found the problem!
I told this story before but ill tell it again....that being said..... every manufacturer has its problems....
I bought an 01 tahoe new, not a problem for 10+ years.....reg maintenance and normal wear and tear..... my brother liked it and bought an 02..... bad fuel pump within the first 3 months.... traded it on an 04 and had some trim problems....it happens.... its life
Agreed.If you would have seen this cable and how it was put together, you would know someone intentionally let it "slide" by inspection. It was noticeably stretched to the max and not seated properly. I get that things go wrong, I work on cars, but $hit like this pisses me off. Short changing the consumer.
@NathanJax @07Burb will help u out wiyh username^^Those lights look great, they should come like that...
Didn’t do anything with mine cuz it’s gone. But I’m counting down the days to get a Denali over spring break. Gotta travel since they mark them up here for “Adjusted Retail Market Value”. In the meantime I have bent the MINI’s rim from a pothole and came out to a flat this morning. Yay.
Is there any way I can change my username?? I haven’t been in a Tahoe since 2013 lol and I don’t really want to make a new acct.
How many miles did you have?Front brake pads were getting worn so I put on new pads and rotors from Power Stop.
