13 LTZ needs new tires
Blue 04 Z71
Reading PA
My wife's tahoe needs new tires. We bought it with 29,000 miles and we are at 48,000 miles on the stock Bridgestone tires. The outer edges of the tires were worn when we bought it and they are even worse now. Still have meat in the middle but o well. I've had the alignment checked and it's all good. I'm chalking it up to the Bridgestones being complete garbage. The last set of Bridgestones came on my silverado and they were garbage also. So I am seeing what everyone else reccomends. I was looking at the Michelin ltx series as I've had good luck with them before.
niely
Fort Wayne, IN
If you want a good all around all season tire, as all Michelin's are, than I think the best are the LTX M/S, but they are pricey at about $200 per tire. Continential also makes a great tire Crosscontact LX20 for only about $150/tire. I've also had great luck with the General Grabber's. The firestone destination LE2's are also good at $180/tire. Last but not least if you want a meaty looking tire that is still pretty quiet than I recomment the T/A KO2's, which I have and LOVE. See pic of the diff setups i've had but the best so far is the T/A KO2's (middle pic).
IMG_20170307_165530 (1).jpg IMG_20180125_162621 (1).jpg IMG_20160218_162235 (1).jpg
RST Dana
OH
View attachment 193257 View attachment 193258 View attachment 193259
My originalbridgestones on my 2013 went for 60k miles. Then I put on michelins, and had noise and wear issues until I traded it last month for the 16.
niely
Fort Wayne, IN
That's great wear! I've never had bridgestones and have had good luck with the others, hence my comments. Weird how everything affects treadlife (suspension, driving style, weather, etc.) So many factors
mtc1328
Indianapolis, IN
Dan, Did you experience any greater rolling resistance with the KO2s due to their additional weight? I had the KO2s on a Nissan Xterra. While the tires were awesome and had barely any wear after 15k miles, I could feel the weight difference. However, the Xterra is a smaller, less powerful truck.
niely
Fort Wayne, IN
Minimal....at most...and really not enough to stop myself and even think about it
I use goodyear eagle ls-2 and/or sport, couldn't be happier, seems to be a happy medium between too hard and too soft for other brands, stick to the road like glue even in heavy rain, virtually zero road noise, very decent mileage. speed rating V (149mph), they are only offered up to 20"
just my .02
MDJR
IL
I've had the Michelin tires before ltx ms2 I believe and they were fantastic. I now have the general grabber at2 and I really like them also however I took a 2mpg hit when I switched to the grabbers. Both sets are wearing well. Only problem I had with the Michelin tires are tiny cracks, like dry rot after 4 years. They were less than half worn at 45k miles and I only ditched them because I bought new wheels.
Sent from my SCH-I535 using Tapatalk
My truck came with Rugged Trails in LR E. Truck did not coast and felt like it had a high stall torque converter with those tires. They weighed 50lbs each. 12lbs more than the stock Goodyear Wranglers. Replaced them with LR C BFG KO2s and they weigh 45.5 lbs each. Now the truck moves! If those are 20s in that photo, the KO2s are LR D in stock size and still 53 pounds each.
Awesome tires the KO2 but if I wanted the best highway tread, it would be the Defender LTX in LR B (62115).
Blue 04 Z71
Blue 04 Z71
Reading PA
The k02 would be a little to aggressive on the wife’s daily haha. I appreciate all the info though fellas!
even though its A little agressive for your wife but knowing you have a good tire to keep your wife safe and sound it's worth it!
Exactly. The truck does not budge flying through heavy rain. I have 4WD and haven't NEEDED it because of these tires.
A buddy has a 4WD Silverado with Toyo LR E highway tires. He needs 4WD to get through his fields while I can follow right behind in 2WD with the KO2s.
Charles Land
Every time I have purchased a brand other than Michelin, I have been disappointed. Get over 100k per set of Michelin tires except when there are road hazard issues - nails and screws on the edge where they cannot be repaired. I watch for the Michelin promo - usually $70 off on a set.
Hrocks
I have had the Bridgestone Alenza factory tires on my 07" Escalade (22") and my '10 LTZ. (20") I replaced the Tahoe tires after 65,000 just because. I have a '16 Lexus GX that had factory Michelins that wore pretty quickly and replaced them with the same Bridgestones. (20") I'm obviously very satisfied with the tread wear and performance of that particular tire.
Blue 04 Z71
Blue 04 Z71
Reading PA
I honestly don't know how you got 65k out of them. Unless the previous owner ran autocross with this thing i don't know how the edges got so worn. Like I said the centers have some meat left but this past snow we got my wife was sliding all over. I have hankook dynapro ATM on my daily driver 99 Tahoe and that thing didn't skip a beat in 2wd in the same snow.
Tires worn on the outside and with more tread on the inside is a sign of under-inflation. The door sticker for my truck says 30 psi all around. If one puts a larger tire on the stock wheel the air pressure needed is even less.
Blue 04 Z71
Blue 04 Z71
Reading PA
Tires worn on the outside and with more tread on the inside is a sign of over-inflation. The door sticker for my truck says 30 psi all around. If one puts a larger tire on the stock wheel the air pressure needed is even less.
Tpms and I keep them between 33-36
Blue 04 Z71
Blue 04 Z71
Reading PA
Update
Ordered the Michelin defender ltx m/s and I ordered all new acdelco tpms. Michelin had a $70 mail in rebate too. Not dealing with a sensor dying after I get the new tires on. The originals are still working but they are from 2013 and are going to die soon probably. Dealer wanted 85 a pop! Got 4 new acdelco for $123 with a 2018 manufacture date.
6point2lovelifers
