Suede door panel accents
thehoe92
fo sho
The916
is 77 stronger then 90? I have several cans of spray 90
90 is higher temp resistant than 77
not overspray, i was asking that if you hate the way it came out and wanted to go back to normal could you just clean the glue off and be done
92-didnt you spraypaint your speaker grill cover too?
I'm sure you'll be happy with it.. I now look at old videos and pictures of my hoe and wonder why I didn't do the suede faster it looks very nice :imo:
I honestly wouldn't try to take it off and clean the glue off but IF you really wanted to I'm sure it could be done since the glue is going over vinyl. I would try and use 3M spray adhesive remover same stuff I used for my side moldings and emblems.
I use 90 high temp because im in CA, 77 peels off when it gets hot
if the surface underneath is prepped properly 77 will do its job in the heat. I still would NEVER trust it on a headliner but for a door 77 will work I'm in CA as well
Bailey-Hoe here you go
http://www.customspeakerpods.com/00-06-Full-Size-Trucks_c44.htm
IIRC a picture of his door pods are even on that website!
NJ04HOE
Paterson, NJ
Yup that's me, he decided to use the pic because when I first emailed him he only had pods for 2way components. After going back and forth for a few minutes he actually made them after I told him specifically what speakers I had (the same day).
Since I brought them I notice the website has alot of updates, now he even color matches them and it says that the newer ones fit better...Damn! I guess that's the price I had to pay for having a one of a kind set.
NJ-HOE,
Sorry to hijack the thread but what are those pods and where did you acquire them?
Searching as we speak...
BB
92 nailed it
Narco
Narco
Atlanta
92 - you also painted your speaker grill cover didnt you? wonder of gloss or flat black would look better for that
brndns_hoe
Plano, TX
i did gloss on my speaker grills...cuz that's all i had, but I think it looks good....i did a couple other pieces in the vehicle also, and those I think would look better flat black....it's not bad, i got used to it, but still think flat woulda been better.
Narco
Narco
Atlanta
yeah i was leaning toward flat. maybe ill play around with the suede this weekend. found a 40% off coupon for joann =)
Narco
Narco
Atlanta
onlone. i googled "joann printable coupon" and found this one. it expires 01/09 so i guess ill be getting the suede this weekend.
its for 40% off any single item. they said 1 cut of fabric is 1 item so ill get 2 yards so that should equal 1 item
thehoe92
fo sho
The916
yeah online is your best bet unless you go through the ads in the newspaper like my grandma does haha!
yeah I did paint my grill, I used flat black but I want to see what glossy black looks like I need to repaint the back doors because too many people kicked them and scratched some of the paint off.
Narco
Narco
Atlanta
you got your PB account fixed yet? i wanna see more pics!
Narco
Narco
Atlanta
in money? maybe $50-75 bucks. in time? who knows, never did it before. i dont mind spending hours on something if im doing it right and it looks good.
you wanna do yours too?
thehoe92
fo sho
The916
my PB is back but theres not much more in the way of pictures of suede
I'll see what I can find though...
and as for time it takes about a half hour to do the top part, and maybe a little less to do the carpet
Narco
Narco
Atlanta
awesome, post any others you come across. does the suede lay flat and smooth on the carpet?
thehoe92
fo sho
The916
thats about it for the suede pictures unless you want me to take some of what it looks like currently..
yeah I was talking to Meade about it and he said to take the carpet off because he did that to the EXT he put croc in and he said it was a *****.. I just left it on because its more padding but yeah it lays flat. the tricky part is finding somewhere to tuck the edge thats why its really important you cut as close to the edge as possible with a VERY SHARP razor
Raja_the_one
Riverside, CA
http://www.gmfullsize.com/forum/showthread.php?t=141110
there ya go...
on my door I left it on to do the top part, for the carpet I took it off and masked everything off..
second time I did it on my buddies left the door panel on but still masked off the rest of the door of course..
theres his turned out WAY better than mine but then again I had practice
what do you mean?
over spray? or if you decide you don't like it once its dry and want it off?
over spray just use some paint thinner and rub it off doesn't take much if its wet still
didn't have a picture when I posted so I just took one lol
still have no clue what its called but try calling that number see if they have one its definitely one of those tools I'm glad I had around
Guys, try this link below if you are looking for this tool.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=95532
rgaffney
VA/GA
ive been thinking about doing this, but im wondering how difficult it would be
thehoe92
fo sho
The916
that could work as long as its nylon it won't harm anything
your buddies came out pretty good..Is that tool useful to install the suede??
Yes! VERY helpful without it I would be using a screwdriver which could ruin the panel or possibly rip the suede..
you have to keep in mind that on both my buddies and my tahoe the top part isn't glued so the way the suede stays in is by tucking enough in the groove for it to hold
just patience.. I would look at GM Full Size and start to do it and if theres a part you get stuck on.. stop.. post it up here and I'll walk you through it I've got enough practice with it I know how it should go
rgaffney
VA/GA
word ill get to playin around with this and post up any trouble i have. much appreciated
briannorris
