Changed Purge and Vent and still slow refuel
Coach Larry
2005 Yukon XL Denali extremely difficult to refuel. I changed out the canister and the purge valve and still no better. No codes present. All fuses are good. Where is next place to look? Can I assume that something is closing the vent solenoid? Or would there be another location where there could be stoppage? I have a multi-meter.
Thank you.
Parts used: AC Delco
214-1105 purge valve
214-2149 canister
from what I have read before there is some kind of vent hose on the upper filler tube that gets clogged up and you have to change out the filler tube to fix it and I don't think the dealer sells them but it looks like dorman offers some, this is just a example I didn't look up the year or anything, my ex wifes burb does the same thing even after I changed the purg as well, you try reading about it more first though I haven't done much more research on it yet
https://www.summitracing.com/parts/...dZHzQ_cOliIr0GVf9P18QhXUDrcuH0fhoCXNQQAvD_BwE
I was reading on another forum now that there is also a switch under the hood? aside from the canister and purge valve
at any rate there was also this comment
"My issue was determined to be damage to the evap lines and hoses that run above the tank. I finally decided to drop the tank on the idea that I would replace it, since I tried everything else and nothing seemed to fix it. When I dropped the tank, I noticed that someone had been there before me, the evap lines and fuel lines above the tank were crushed. It seems that a protective plate was missing, and when the tank was raised the lines got crushed. After replacing the tank and those lines, the truck behaves like it should, takes gas without shutting off the pump. Quite an expensive problem, since it's a good idea to also replace the fuel pump and seals since the tank is down anyway."
C
Coach Larry
Good info there Doubelieve. Sounds like I have some work to do to flush this one out. Thanks for those!
UrbanSuburban
On my 04 Suburban, I was having a devil of a time filling up, it would pump 2 dollars then shut off, I tried pulling out early and letting more air our from the tank and nothing would change. At first I was blaming it on the stations hose gun, some are more sensitive than others, but it would not do it and then do it on the same pump and nozzle. It drove me and my war department nuts when the time came to fill it. I did change the vent the purge canister and solenoids. I even spent some bucks and got a GM filler tube as mine was rusty anyway. The new one did not come with the overflow tube but it was fine to work. There is no valve inside this tube so elsewere I went. It turned out that inside the tank filler neck, the plastic part that protrudes before you slide the rubber fill tube over has a flapper inside. This flapper is for rollover protection. What was happening was this flapper was staying closed about 90 to 95 percent of the time and when it came time to fill up, the fuel backed up into the tube and stopped the gun, but it did not do it all the time. One of the good ole boys who was a gm mechanic told me to force this flapper into the open position and viola, problem was solved. No more fuel back up and war department was happy again.
C
Coach Larry
Interesting one. I am definitely adding this to the list as this is driving me nuts and i have same symptoms exactly.
Always good to keep the war department happy.
LINTZ0718
Thank you.
214-2149 canister
Im 15 year Chevy tech for a dealership and it usually the cansister for the hard to fill concern
LINTZ0718
97% of the time that’s problem. Vent went bad and pulled gas in to canister. Pull canister and shake and see if has fluid in it
when I changed my ex wifes canister in her 04 suburban it was bone dry, the problem was still present immediately afterwards, it has been a little while since I have checked it, presuming I pull it again and it has gas in it, then how do I deal with this "vent"
LINTZ0718
You need to read full tank pressure sensor with a scanner that tell if bent is good or bad
HiHoeSilver
Away!
Chicago
You need to make sure the lines are clear. There have been plenty of reports of the charcoal pellets clogging the vent line.
so could I in theory just shove a wire thru it or something? I am not too concerned about this so much anymore but if it is a easy fix with something as simple as that then I guess I could try it.
HiHoeSilver
Away!
Chicago
When you took off the box, did it rattle? The pellets break loose and can find their way into the vent. Can't find the thread(s) now, but there are a couple...
I replaced the box in the summer, I think the old one did rattle when I took it out that's a good point I didn't think much of it then.
CKendrick
