Subwoofer remote control knob
Unit171
NC
If you have no bass.... do you still have your factory sub hitting notes?
Is your aftermarket sub not hitting? Do you have a remote control for your LC or aftermarket amp?
Q
Qlassic418
I thought with the lc2i there was no need for the 12v and ground because of the gto technology that is turning it on
Q
Qlassic418
I have power to my lc2i
The factory sub still hitting
But my aftermarket doesn’t
Unit171
NC
Good, what was wrong? And I just went and did my remote control knob with pictures for you.
Unit171
NC
Here are my two controls. Blue is the amp punch and yellow is my LC2i
E2B31D1E-DE10-4775-92B9-949B56C22722.jpeg C2D722A8-B72B-46A8-B961-F800FF630AF2.jpeg
Unit171
NC
Here is the under side of how I did it. First I took the LC2i control apart. 2 screws.... then loosened the nut and removed the chip/LED/control. I used the face of the control housing to mark my holes and simply drilled them out. Once drilled and cleaned, I put the chip/control in place and used the nut to hold it in place from the front.
6553673D-E06E-463A-AB86-98DC1E1DD8E6.jpeg 8BCC8352-F8E8-4ADB-8625-0A6D8E94AD75.jpeg
Unit171
NC
Next I took the punch control apart and used the face to make a template
Unit171
NC
With the punch control I had to use the housing and cut part of it down to use the face portion as a means to secure that chip and led in place. I simply drilled those holes and put that chip and cut down housing in place. Secured it with super glue initially then hot glue too for safe measure.
Unit171
NC
Lastly I had to cut some of the plastic that holds that cup area in place to allow room for the cable to plug in.
Unit171
NC
Everything is back in place and works/looks great. Took about the time for the Panthers to play the 2nd half of their game and win btw
Unit171
NC
Hope this helps someone feel more confident in drilling that new plastic!
Q
Qlassic418
First it was my power to my lc2i then my sub disconnected in the box
I mounted my knob a the same spot
I will change my subs soon because i a a great deal on a JL Audio 10w6v3-d4 with and ** box
I have 2 alpine type r swr-1022
schafer98
