Has GM fixed the buffeting and vibration issues?
acainindy
Knoxville TN
So as much as this pains me to say, I’ve had my 18’ Tahoe 20 days and 1000 miles and my head is about to explode, the pressure in my ears is so bad that I have constant headaches, feel motion sick all day and wish I knew about this problem before I ordered my truck. I took it into the dealer yesterday, filed complaints with GM, and with the NHSTA. Because my truck has so many GM upgrades, ordered and delivered with them installed my dealer says it will be difficult to determine what is causing it. They also say they never heard of this issue....Hmmmm. I showed them two News reports from ABC and Fox.
Now I’m waiting for the call, “ we can not find the issue”. If so, I can no longer drive it, my wife won’t even get in it after a drive the day we took delivery, it made her sick immediately! WTF
Who has dealt with this recently, need pointers on what to do, or what their fix was. I Love my Hoe, and don’t want to get rid of it.
My Yukon SLE is a early 2015 model year build:
Since having my vehicle at the dealer in January 2015 (19 Days) the service department has completed the roof cross member re-attachment, road force balanced, alignment, new drive shaft, then new wheels and tires. The pressure/thumping noise was heard by the technicians and the service manager after all of the above things were done. The vehicle was back at the dealer in February 2015 for 11 days. The dealer had the zone area service manager come and drive the vehicle, he felt the pressure. Then the service concern was escalated with GMservice and an engineer was assigned to the case. He came out and drove the vehicle with me and the service manager. He heard the thumping and felt the pressure. As soon as we got back, he contacted the plant in TX and had a new Ring and Pinion sent directly to the dealership. After the tech replaced the ring and pinion the thumping/pressure is basically gone. The old ring and Pinion had excessive wear and uneven wear on the teeth. The engineer decided to put a set of Michelintires on due to some road noise/drone after everything else. They are still dealing with one related issue. When switching into Auto 4WDor 4WD High, the thumping/pressure concerns come back. The tech and engineer are going to check the front axle and transfer case next week. I have to tell you that the service dept. and the GM technical service group have been very helpful and have been trying to attack the issues. I will update again after they investigate the Transfer Case/Front axle issues....... They replaced the front Ring and Pinion and all the thumping/pressure went away. I haven't had any issues since February 2015........... Alex
Phil25101
I ordered my truck and took delivery without test driving. I had driven another one prior to ordereding mine and did not experience the pressure in the short drive. I also knew nothing about this issue until this past several days. Googling “does your SUV make you sick” wasn’t a thought. I owned a 2007 for six years and had zero issues. I didn’t start feeling sick until it had 300 miles on it. But my GF felt it right away. My Hoe has the GM Borla exhaust installed as part of by build which now the dealer is saying is the cause “drone” I know it’s not the exhaust drone as the pressure is constant on or off the gas ugh
acainindy
Knoxville TN
Have them check the ring and pinion gears!
Tahoe14
Central Fl
Phil, you need to check the Lemon Law in your state and follow it to a T. Document,document,document. Contact a Lemon Law attorney in your area, easy with Google search. In most states you do not pay up front and his/her fees are part of the settlement. Don't expect any help from GM corporate, they are not your friend. Ask those of us that have been through this how we know, been there done that. Good luck.
cardude2000
Sorry to hear. Ugh.
Can’t believe chevy hasn’t figured this out yet.
JayceeP
Just test-drive a 2017 Yukon XL SLT with 18,000miles and I feel like there was a bit of buffeting/pressure. I couldn't hear anything but I do feel like my ears were developing a bit of a popping sensation.
Anyway, I was definitely underwhelmed by the test-drive. I think if there was a 10sp tranny it'd be better. The 2nd row legroom is also no good with the driver seat back and the gas pedal is too close to the driver seat for me. I thought I had better memories :(.
Phil25101
Well I’m back, so dealership said after a 30 miles test drive “it was like being in a torture chamber” because I had the Borla exhaust installed as part of my build and prior to taking delivery. They said it’s the exhaust drone and put back on the OEM system. I drove it home so far 5 miles, I’ll drive it tonight to see if that was the fix. I seriously doubt it. While washing the truck last night, I observed a lot of play in the roof sheet metal between the front and first roof bow. I’m betting it’s not bonded which Perpetuated the exhaust drone in V4 mode.
Which is exactly what GM put out in PIT5318C. Hmmmmm!
ajs800
Michigan
Is the buffeting still present? The TSB may work but you'll see over the last 2-3yrs that in most cases it did not fix the issue. Will be curious to hear if the exhaust was the main issue or not.
gat0r
DFW
i doubt the borla exhaust is main culprit.
given all the other threads & possible but not successful fixes out there.
i'd say the dealer is being lazy & blaming aftermarket, even though it has a GM p/n for the borla.
they need to look @ other items.
i think it goes to tolerance stacking... i'm thinking its a combo of fixes that actually fixes things.
ajs800
Michigan
true but sometimes, peoples idea of "buffeting" vary. Maybe it is the exhaust given his wife had issues the first minute of riding in the truck. I'm hoping the 18s aren't plagued with the same issue. I may just be taking a chance on a new model 18 expedition.
Phil25101
We drove last night and the buffering was almost gone, the wife who said she would never ride in the truck again, said it was tolerable now and she barely felt it now. But did complain when driving in V4 mode. I’m unable to tell because my ears are so messed up from the last 20 of driving in the “torture chamber” everything hurts my ears and Equilibrium. The true test will be my 40 min commute tomorrow to work.
The Borla system does not have the valves to compensate for V4 mode and was a major contributor to the buffeting drone. I don’t recommend this system to anyone. Although it did sound awesome at WOT. !!
I believe the truck is still going to need another fix to resolve the issue. IMO the roof is the next fix as stated before in earlier post. My roof has too much flex in the area between the first roof bow and windshield. I’m going to stop at the dealer today while they are closed to check other Tahoe’s for the same flex. If not then that’s the next step.
gat0r
DFW
@Phil25101
curious , do you have the roof cross bars installed?
wondering if those could help any.
JayceeP
Bumped this just so more people could see it. Good info.
boal05
New member here, and for every vehicle I've ever owned or considered buying I scour the forums to find info, so thank you to all that have been on here and given your insight, I've learned a lot through your posts!!
I've been looking for a few months now, for 15/16 Yukon Denali for my wife to replace our 12 Honda Pilot. we love everything about the Yukon, however I'm concerned now after reading a ton of info on the buffeting and vibration issues. The hard thing is searching for the color she wants and being able to test drive multiple vehicles before buying. Is there anything else I can look for or ask the dealer about when considering a Denali? We test drove an SLT today, and I didn't notice anything, although we didn't get up to highway speeds, or over 45 at best.
I've read everything I can on this issue, but I'm hoping some good tips or advise might help when I'm looking at Denali's that are 2-4 hours away and I'm nervous about making that trip only to find out it's a Lemon!! with no fix to this issue in the 15-17 models, should I just look at something else or wait it out? Thank you in advance for any help or advise, much appreciated!
Tahoe14
Central Fl
First off it does not affect everyone the same. Some are more prone to the issues and notice them more to the point of headaches and even sickness. Test drive at different speeds and always check the car fax for excessive dealer visits.
jet black slt
Johnstown ,Pa
It’s been a good while since I’ve posted on the forum, But I bought a 16 Yukon Denali last September. Initially the vehicle was perfect, however it developed the buffeting issue around 3k miles. After reading all the issues I traded it in within a few hundred miles of that. These trucks cost way too much to have this issue IMO.
15YUKON
The 15 and 16s have some tranny reliability issues on top of the vibrations and noises. Look for hard shifts and delay then a smack into gear.
Phil25101
Well, I dropped my Tahoe back off today at the dealer for round two.
Today, the pressure was intense from 5-10 mph while on rough pavement, as soon as I went onto smooth pavement that pressure stopped. Weird as it’s not a drone issue but possible a suspension issue. IDK, that’s for them to figure out. It just sucks because I’ll take a bath on this truck to trade it in. I custom ordered it with $7k in options, put another $1.5k in paint protection and stereo upgrades into it. Ugh I’m so disheartened
ajs800
Michigan
There are a lot of (16/17 models) trucks used with only 5-10 thousands miles on them for sale which makes ya wonder. I'd like to find a used 17 with very few miles but given the issues with our 15 XL, it's going to be new or walk from gm. It's amazing 3yrs later And They still don't have an answer for the buffeting/vibrations.
I'm Going to test drive a few "new" 17 and 18 XL in the coming weeks and will then decide which direction to go.
SuburbanPassion95
