Popping from front end
02_Tahoe
Maryland
When turning sharp at slow speeds I can hear a popping noise and I am positive it's from the front end because I can feel it in the steering wheel. I checked my ball joints and there is no play. Any ideas? Also just replaced tierods hoping to get rid of it but no luck. But some good news is I'm getting 18.5 mpg on the highway, so that's a plus
Chubbs
Don't sound so optimistic, that 18-1/2 mpg goes to ZERO when it's on 3 wheels as it goes from a pop-pop-pop to a "BAMM!"
:banghead:
Chubbs
Calm your ****. If I knew what was wrong with your truck I would be the first person to tell you all of the possible sources. Problem is, I have a "pop" noise too that I cannot locate, hard as I try. If you have ever attempted a search on this then you know what I'm talking about. Very rarely is 1 mans "pop" or "thunk" originating from the same place as somebody else's. Some people spend $1,000 rebuilding the front end and still, "THUNK!"
If it's not the front suspension, steering linkage or driveline then you have to look at the body mounts, crossmembers, motor/trans mounts, slip yokes/Ujoints, torsion bar crossmember isolator bushings, intermediate steering shaft bearings... IDK you tell me if that helps anybody. To me, this would be a smartass response.
Have you checked your swaybar endlinks? The rubber isolators are known to deteriorate.
Most def
Would that really cause popping noises
Most definitely. I have a rear endlink with a bad bushing and it's making a popping noise when I drive over something just right. Same would go with the front and it's an easy visual inspection. Have you looked at them yet?
02_Tahoe
02_Tahoe
Maryland
Most def
Oh I've looked at them before and they are all cracked up and dry rotted. Never even thought they could cause it
PG01
Up here to the right
My pop, thunk, clunk whatever has been there since i drove the thing off the lot new in jan of 2013.... only on left turns....59,000 later and its still there..... doesn’t bother me enough to look for it
02_Tahoe
02_Tahoe
Maryland
With my luck if I don't try to fix it I'll hear a loud pop and watch my tire go rolling away
M1Gunner
Gainesville, Fl
Did you have your keys cranks up at one point and recently lower them?
If it's only when you're turning that your hear this popping noise I feel very strongly that it is your CV axles.
02_Tahoe
02_Tahoe
Maryland
Yeah I did lower the keys a little bit because the back settled a bit and the truck was squatting. What would that do though?
kwOH
Banned
When I first got my 05, I had a popping going on, checked ball joints, tie rods, changed the cv’s. That wasn’t it, torsion bar cross member mount. If you live in an area with snow and salt, there are rubber mounts on each side of the crossmember that help it flex as the torsion bars twist, the salt drys out the rubber mount and it wont flex as it should and starts to pop as it moves.
02_Tahoe
02_Tahoe
Maryland
Yeah I live in Maryland and everything on that truck is rusted underneath so I guess that's a good possibility. Didn't realize how many different things could be causing that pop. This is going to take a while to figure out
Yeah, pretty much anything that moves.
Skiroy56
