I went with 3157. Same socket and since its an LED bulb, I'm not worrying about heat.
Did a little shootout between parts store tire pressure gauges. Looks like the Slime branded one is as good as my Longacre one!
Thanks, I've never had a decent gauge. I just ordered the Slime one.
05Single
afraid of the dark
Yes socket and base is same. But the watts is different. Causing the 3157 to burn out fast
MINIz guy
Interesting, guess that's why I saw 4117 as recommended but 3157 as one that still fit. I'll see how long these last and then get a new pair if they burn out
BigDaddy13440
Rome, NY
Got my replacement last week for my blown led. View attachment 183412
Where'd you get the replacements from?
Those look identical to the ones I have, but I got mine off E-bay. I had one die on me less than 2 weeks after installing them, the seller sent me a complete kit for $15 shipped. I now have one of the two LED's out in my driver's side, I need to have a couple as spares.
I bought mine off Amazon. The seller , based in Hong Kong, shipped me the replacement. First I had to cut the wire coming from it and send a pic to them, so they could verify I wasn't trying to rip them off.
BigDaddy13440
Rome, NY
I bought mine off Amazon. The seller , based in Hong Kong, shipped me the replacement. First I had to cut the wire coming from it and send a pic to them, so they could verify I wasn't trying to rip them off. View attachment 183424
I think EVERY one of those are coming from Hong Kong, it's just a matter of which of the thousands of 12 yr old girls in the factories made it....
I would be more than happy to be able to get just the bulbs and fins. The ballasts work fine.
gat0r
DFW
i like my longacre, got it last year. but i didnt opt for liquid filled.
i liked it better than the other cheaper versions... b/c the cheap ones have a +/-4# allowance
the LA has accuracy of 2% & reads in 1/2# increments. think it was a deluxe model for about 35
Crap now I had to order a Longacre. You guys are killing me lol. Just kidding; now I'll be able to see if the Green Slime is accurate.
MINIz guy
I couldn't find accuracy on the Slime one. From my unscientific test, both my Longacre and Slime one read the same.
I will say, I wouldn't trust the Slime liquid filled gauge. There wasn't a bleeder for it, so I don't think it will be accurate if it is super cold or super hot out.
I have 2 of the liquid filled Slime gauges, and both have a bleeder valve on it.
MINIz guy
Air bleeder or bleeder for the gauge?
I know they can bleed air from the tires. I'm talking about a bleed valve on the gauge itself so the fluid can equalize to atmospheric pressure. My Longacre has that, and all the replacement heads still have that. Without it, they say that the reading can be off since the can be more/less pressure in the gauge than the environment it is in.
See the knob on the top of the gauge, not the bleed valve on the neck.
T
new heads and tails
Those headlights are sweet!!!
OK, gotcha. I thought you were talking about the bleeder valves to let air out of the tires.
Merch619
