Brake upgrade options?
2016YUKONSLT
2016YUKONSLT
I did. Ran into a couple issues as they don't fit a 15/16 directly. Had to grind on the spindle and then use the shims. Once all that was figured out, I'm going to have to find a 1/8th inch/3mm spacer for the front OR grind on part of the new caliper and then get it powder coated again. But before all that, the calipers need to be repaired as there is some manufacturing issues with the ports. They look clogged and caused leaks. I'm waiting on vendor to send me a new set and will return these under warranty.
2016YUKONSLT
2016YUKONSLT
Noticed that there is now a performance brake kit option for Tahoes in my dealer's accessory catalog. Not sure if they could but put on a Yukon though...
I wonder if these are the one for the Tahoe RST?
chicagofan00
Arizona
I believe they are. I could have sworn they had mentioned in one of the press statements that the exhaust and big brake options were going to be available right away...which we already knew the exhaust was available. Not long after the announcement the brake option shows up.
2016YUKONSLT
2016YUKONSLT
They are a 6 piston caliper with a larger rotor for $2600. Wilwood is still cheaper by $500 off summit.
duke90
Corona, CA
If anyone has a used big brake kit (Brembo, Wilwood or Stoptech) they are looking to sell please send me a PM Thanks!
BadDaddy2003
