2007 Yukon Denali Build (This got outta hand really quick...)
67RS427
67RS427
Comp Cams Trunion Upgrade Failure...
http://forum.grrrr8.net/showthread.php?t=35225
Lots of others. Take note of what Livernois Motorsports says on the matter. They build thousands of LS engines and do lots of dyno work both engine and chassis
Confirmed: Comp trunion 'upgrade' is a DOWNGRADE
http://grrrr8.net/showthread.php?t=45352
https://www.corvetteforum.com/forums/c6-corvette-zr1-and-z06/3802785-failed-comp-cams-trunions.html
Lots of engine builders swear by the stock rockers, mine and myself included... Again GM spent millions on R&D and failures are rare if you consider quantity out there
67RS427
67RS427
Where's the link
For what? I put 3 links about Comp Cams Trunion Upgrade failures in the previous post. #101
Edit: Also keep in mind that these are the same rockers used in almost ALL LS motors. LS1/LS2/LS3, LS9 and L92... That means the 2012+ CTSV/Camaro uses these rockers and a lot of Corvettes and other high performance high revving cars. These guys are making 600 - 650+rwp on stock rockers. Food for thought... Not that many failures considering the MILLIONS of them out there.
FamilyTruckster
Awesome Dude McChainsaw
Detroit-ish, MI
Really glad I just came across this build! Will def be following along!
I've been running the 1900 mag for over a year now and I believe I just threw a DOD lifter... not sure yet if the cam is toast as well, or the extent of the damage... testing into her on Tuesday... considering dod delete and obviously a cam while I'm in there... any suggestions? (Not to hijack your thread, looks like you're on top of things lol)
67RS427
67RS427
I'd be happy to help... Michigan? I'm White Lake/Commerce area. Just started browsing your build thread, I like it. How do you like the gauge? I dig the corner gauge setup. I also have a steering wheel pod I may install and a 2 gauge pillar one also but I don't think I will like the look. Yours looks slick...
Tear it down and let us know the extent of the damage. Go from there... I know some great machinists if you need someone.
From what I understand there was an issue a few years back but it has since been resolved. I'll pull mine in awhile and check but thanks for the heads up. BTW one of those threads is from 2013. I've heard about what happens if an OEM one fails and even though rare it causes complete engine failure due to the non-captured design. Damn if you do, damn if you don't.
67RS427
67RS427
Thursday I was able to get both heads back on with the +.060" Cometic gaskets and ARP bolts torqued, also received my new comp pushrods so I also got the new lifters and rockers in. We were even able to get the LSA installed but I didn't have time to take pics. Getting back at it at 8am on Friday. Here are a few teaser pics below, blower coming pics tomorrow. Headers and Y pipe already back on as well. Should have Muffler and SLP resonator delete installed and the belt drive all finished tomorrow. Had some alignment issues with the idler pulley bracket so I might have to machine something. Will see how the alternator lines up in the AM... Stay tuned!
67RS427
67RS427
I wrapped up today with some great progress. For the most part the supercharger install is done with only a few minor things to do still. Still need to get the heat exchanger mounted and installed as well as some wiring and intake fabrication but I'm very happy with where I left things off. I could have rushed this and done a back yard install but in the end I'll be happy I took the extra time to make sure everything is wired and ran correctly looking OEM. I had to make some modifications to the bracket kit I received just incase I want to remove water pump bolts without removing idler pulleys first. Everything lined up great and the belt rides in the MIDDLE ribs on the supercharger.
Missing the finished weld picture of the idler bracket but I will update post when I pull it to paint. Also need to paint the Alternator/PS pump bracket and the PS Pump itself...
i.php
Belt fits great, not too worried about belt slip at the moment but might be an issue when I downsize the pulley to increase blower RPM. Factory truck damper is only 7.5" vs 8.5" or larger on most LSA vehicles. Basically don't think I will be making enough boost but we will find out soon enough. I am ready to pull the trigger on an interchangeable blower hub/pulley system if needed.
i.php
Kooks Y Pipe Installed...
Tomorrow (Saturday) I should have the heat exchanger installed and most of the other odds and ends wrapped up. I will try to take more pictures, been very hard to multitask.
juan84
Mounds view MN
Looking good!! How's the clearance with the front drive shaft?
Sent from my SM-G920T using Tapatalk
67RS427
67RS427
I don't see it being an issue... I will take a better pic tomorrow. Here is a larger pic of the Y Pipe. Clearance to the transmission pan is good too, almost wondering if I should go with a deep finned pan with a drain plug. Changing transmission oil on these is a pain and messy...
I'd def do the drain plug. You'll be glad you did it the first time you change the fluid.
juan84
Mounds view MN
Looks like plenty of room thanks
about20ninj45
i.php
i.php
Whos brackets did you use?
67RS427
67RS427
Brackets I got were from NextGen Performance, Link below... Only reason I had to modify the idler bracket is because my VVT setup. Seems the tuck water pump was revised or is different for VVT as it has a bulge where the bracket couldn't sit flat. I was able to fix that easily with 2 small cuts and a weld as seen above. The truck water pump also has more room behind it for the VVT stuff at top of the valve cover. I guess all in all if you were to do this yourself on a VVT truck I would suggest getting an F Body water pump and then get their kit that comes with 3/4"(?) spacers to get it lined up properly. Nothing I couldn't handle though.
These guys were in HotRod magazine for the whole swap thing... Both links below
http://www.hotrod.com/articles/next...-blowers-new-life-4-8-5-3-6-0-gen-iiis-heres/
http://lsspeedshop.com
If anyone is looking for a set of Kooks Y Pipes, PM me. I have a brand new unopened box I am willing to let go at a reasonable price/offer. I'm in South East Michigan if anyone local wants to pickup.
CrackerJack135
