99 Tahoe Tune up
Hoodon
Alberta, Canada
Greetings,
I cant remember the last time I had my plugs replaced on my Tahoe. I'll probably do that this spring when it warms up, ( I don't have a heated garage to get it done)
I was wondering what other things I should do for a good tune up. I will probably throw a can of SeaFoam in my tank, I don't do a lot of highway so I'm sure there is some gunk in there.
So here are my thoughts:
Plugs - any suggestions?
SeaFoam
Check transmission fluid/ flush transmission fluid
Fuel filter - any suggestions?
Anything missing?
Thanks in advance
99Yukon_Z71
Crazy Puerto Rican
Humble, TX
Dont forget Cap and rotor assemblies, plug wires, air filter, and lube undercarriage especially if in bad terrain. As far as plugs, I am running the E3's on both my 1995 Burban and 99 Yukon with no problems and awesome performance. Check em out!
cmcarr85
I just did a tune up on my 97 Tahoe...I did...
plugs
plug wires
cap
rotor
oil
oil filter
pcv valve
fuel filter
air filter clean out
92__silverado
I have always used AC Delco plugs on my chevy's and NGK's on hondas. What are you guys seeing about these E3 plugs that you like. I have read on some forums that people didn't notice any difference.
1BAD9T7
Paso Robles Calif.
I have been told by 2 seperate dealerships to ONLY run the AC plugs... I tried the bosch platinum plugs many years ago, it ran like crap, my brother in law had a 98' Z71, ran the same platinums, ran like crap and would not pass smog. He put in the AC plugs, passed great, no other changes... Something about the vortec that didn't like those plugs... I would recommend what GM used originally based on my experiance...
Jason
Whippled2dr
Stock
SF Bay Area
I agree the stock engine I would stick with the ac delco plugs. On my s/c tahoe I run NGK TR6's but change them out every 10K miles.
wicked2000
El paso TX
I have heard 96 and up should stay with AC delco. The vortech engines run better with them and you wont see difference on the more expensive plugs.
OldWYLawman
