Rotors and pads you guys running
Jon Chimpo
Hey all,
Looking at new pads and rotors. Nothing too crazy, mayby slotted. Curious what you guys run? Also going to to be putting on a new parking brake.
If you're doing new pads and rotors on the front it's a perfect time to also get new calipers because the larger NNBS rotors fit with no modification. There's lots of info here on the upgrade, search for GMT900 front brake upgrade. They're an inch bigger rotor. The only extra cost to upgrade is for the calipers, and the rebuilt ACDelco's are pretty cheap on Amazon, around $70 each I believe.
metelhead
Jeez RR, if I had your wheels I think I'd have 20" Rotors too :)
OP- Powerstop rotors and pad are inexpensive and great stoppers....Always flush you brake lines too when you do brake job..
95escahoe
I run Wagner ceramic pads and there premium rotors they paint the areas that typically rust, still look good after a year
Sasquatch
Orange County N.Y.
I`m running R-1 concepts Eline slotted and drilled for about three years and the rotor hats are still completely rust free and look great. No warping or cracking either and they`re having a 10% off sale right now.
J
Jon Chimpo
Oooo i like that!
J
Jon Chimpo
thinking ceramic, bucause i hate dust. i have some killer pads on my Silverado. they dust up in 2 days.
not a fan on the drilled, and slotted. its one or the other, or solid. Too much surface area is taken away.
I bought the drilled and slotted ones but if I was to do it again I'd just get the slotted ones. I haven't had any problems and they work great but I've heard for big heavy SUV's the drilled ones can develop cracks. Here's a shot of the difference in size between the 07-14's NNBS and the 00-06's NBS. Funny thing is, our rears are bigger than the 07-14's. This is a great upgrade for very little money.
kwOH
Banned
Link?
Sent from iPhone 7 plus using Tapatalk Pro
95escahoe
1992rs
OR
I did the NNBS front upgrade and used R1 concepts premier slotted rotors with hawks lts pads all round, as well as goodridges ss lines. After a year and a half the rotors look new still. The pads dust like mad and lack some bite when cold, but stopping from 90 cannot be put into words for such a heavy vehicle. They've Saved my ass several times with animals on backroads and idiots on the highways.
Aaron_L
Arlington, TX
I run the Wagner ThermoQuiet pads on my Suburban, they work well and don't give off any dust at all. I'll probably get around to doing the later model front conversion, I just haven't had much time to source the parts. Right now I have Bendix rotors from Rockauto, they have held up well. When doing a brake job on my cars I always clean all the preservative off the rotors, and prime and paint them with high temp engine paint. I don't mask anything off, the pads will clean what needs to come off. My current brakes have been on for over two years & still look good.
Mohq
