Throttle Position Sensor/ Engine reduced Power message letter from GM
my09denali
I have 09 Denali.
Received letter from GM today that says: This letter is intended to make you aware that some 2009 model year GMC Yukon vehicles, equipped w/ a V8 engine, may have a condition where the throttle position sensor may cause the engine to run rough and cause the malfunction lamp and/or a Engine Reduced Power message to illuminate. If this occurs, it could result in reduced engine power.
Unfortunately for me I received this letter in the mail today. Monday xmas eve I was stranded on I-94 w/ 20 degree temps in the middle of nowhere w/ my truck in limp mode. With engine power reduced you can't go over 20mph.
The letter states in bold letters don't take your vehicle to the dealer unless you believe you have the condition.
Of course by then it is too late. I talked to a lady at work today and she had the exact same thing happen in her '10 Sierra. Luckily she was in town close to a dealer.
No tow trucks working xmas eve. Took 2.5hrs to get one through Onstar. The dealer I had it towed to in WI said there was a silent recall on the issue but they didn't know the batches or which trucks have the problem but it is a known issue so they fixed it for free even though I'm out of warranty.
Now that I have the letter which has a page to file a reimbursement claim I'm going to file for the $125 tow I paid.
The point of this post is I've had my truck 3yrs w/ absolutely no problems. There were no warning signs. Was cruising at 70 on the interstate and just like that it shut down. Don't wait until your sensor goes out.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
I too got this letter. I have not gone to the dealer but if you tell them it happened and your just cleared it, technically it counts.
TowGMC
Wheaton, IL
I got the same letter, and this past Thursday my check engine light came on. Runs fine, made it 150 miles home in the snow but fuel economy was horrible. Called my dealer first thing Friday morning and he immediately suggested the TPS might be going bad. Apparently there's been a run on the replacement part so I won't be able to take the Denali in for another 10 days, but at least mine's still running.
He also said that since this is a "service action" (his words, not mine) the replacement will be free. But he also said that a TPS failure should be covered under the emissions warranty since a failure would cause the Denali to fail an emissions test.
shooterz
Largo,md
I also had this happen to me last Saturday and disconnected the battery to clear code, so i could get home. Took it to the dealer after receiving this letter two days later and was told that the check engine light had to be on, so they could read the code. As stated in 1st post in bold letters not to take your vehicle to the dealer unless you believe you have this condition. Was told to wait for the light to come back on and call a tow truck.
bolo1g2
My09Denali, I had the exact same thing happen to me. Except I was about 30 miles from home and I drove that ***** the whole way doing 25mph. Got my letter January 5 after I already had it in the shop and had spent $400 on repairs. I took it to my dealership today and the guy was like well i don't know if we are going to reimburse you for the repair as they did the wrong thing. I almost blew my top. I told him to file the paperwork and let me know what happens. If I don't hear nothing, I'll send it to GM like the letter says. But what a bunch of BS. Just like Denali said, no warning or nothing. Just weird shift noise, car downshifted, lost power and then crawled along at less than 25mph.
doubletapdrew
Just ran into this today looking into the Investigate Vehicle History secion on GlobalConnect. On affected vehicles they have "Special Coverage 11273" added in the warranty section which is good until 120k miles or 10 years. The shop said they got the bulletin in Sept of last year. I think it's for all V8s from 2008-2010 or something like that.
Ben
PCB, FL
My truck currently has the light on for the TPS sensor, yippie.
bolo1g2
Got mine back from the dealership today. They said all fixed. Should never happen again. But they denied my request for reimbursement from the shop that did the other work to get the car running again. Said the repairs were for the wrong thing. Really? I never would have taken the car to the shop if it hadn't been limping along? Now I have to write GMC and see if I can get reimbursed from Detroit. I think it's a load of BS and the dealership just doesn't want to pay out anything. But whatever. I hope this never happens again. Just kind of pissed that the dealership wouldn't even acknowledge the reason the car was in the shop to begin with was because of the reduced power. Rant over.
wcsmith21
Baltimore, MD
My 2010 tahoe just started acting up. Last Thursday I remote started my truck and when I put the key in the ignition the whole dash board lit up. Got the reduced engine power warning. Turned the truck off and let it sit. It started up fine. Today the same thing happened. Can't wait to go to the dealership.
Yukon Lover
Maine
Wow pretty cool you guys are getting yours fixed buy dealers or gm mechanics for free! But unfortunately like me (03 Yukon, over mileage)and allot of others on here we have to try and chase this issue and pay for it ourselves. It seams to be affecting all chevy gm trucks and suv's alike. Ive had a code for my app sensor and replaced it and now it runs worse and acts up more. Found a thread on another site that said about testing the voltage at the harness on the pedal sensor (which is way off) but it was a paid response from a gm mechanic and didnt follow through if that means its the tac module or if its can be caused by something else. So still trying to figure it out.
Quag
Folks, I have a 12 tahoe with 5.3 liter. Getting intermittent p2135. Of course when in the middle of no where. I have re set with an odb scanner Ta get it out of limp mode. I have researched and seems the service bulletin on this only goes to 2011. My question is if I purchase a tps kit do I have to reprogram the ecm on a 2012? The service bulletin I read for a 2011 says no.
Yukon Lover
Maine
A good part should have the proper programming already, ask the people you are buying it from.
Sent from my Z797C using Tapatalk
taiblalock
Is anyone still following this thread?
I have a 2010 Silverado 5.3L 4x4. Getting a P2135 code again. It was doing this a while back. I googled the issue and replaced the throttle body, TPS sensor, accelerator pedal, and the pigtail connector to the TPS sensor. All one at a time because each time I replaced something the problem persisted.
Since, I've put headers, cold air intake, and a tune on it. After the tune the problem went away so I assumed it was a programming issue. Now this morning it is doing it again.
So... has anyone figured out what the issue causing it really is? All of the parts associated with it have been replaced with OE parts. I cannot, for the life of me, figure out what the hell is causing it!
Thanks in advance. I appreciate any help.
Yukon Lover
Maine
Don't know about the new ones but, do you still have a tac module involved? Plus wiring to it as well?
Sent from my SCH-I545PP using Tapatalk
harbison
I'm following this thread. 2009 GMC Yukon XL. Had this problem intermittently over the last 2-3 years. P2135 code. Replaced TPS sensor 3 times (lifetime warranty). replaced pigtail connector to the TPS sensor (because I broke one of the clips). Replaced MAF sensor. Stabilitrak, Engine Power Reduced. Any ideas?
harbison
Ordered the AC Delco 19259452 TPS Sensor from Rock Auto ($28.89). Will replace the AutoZone Duralast TPS Sensor 4270. Then have dealership reprogram ECM. Hopefully that will solve the problem. I really would like to hold on to this vehicle since it's paid for.
harbison
So I removed the Throttle Body with TPS Sensor attached from vehicle. Thoroughly cleaned throttle body using throttle body cleaner. Replaced TPS Sensor with AC Delco part. Went step by step through the TSB instructions. Even put the clips on in order. Last night I get "Reduced Engine Power, Stablitrak Off, CEL" code P2135. I popped the hood, closed it. Started fine, ran fine, drove home. The only thing I can think of that I haven't done is to replace the throttle body. I had the ECM reprogrammed at the dealership the first or second time it happened. Does that step have to be every time? Ready to be through with this headache!
Denali2k8
Got a P0011 code on the highway after a downshift. 2008 Denali w/ 6.2L. Is this related? Cleared with scantool and havent had codes pop again, but I feel like the truck has surges of loss power under regular accel.
CKendrick
