Adding an aftermarket radio to 07-14 FAQ
yates ™
Resident Apple hater
Iowa
I see a lot of threads asking about what to get to install a new head unit so figure we should make a sticky with all the info.
This will be updated as you, the experts, give more or correct my information. It has been years since I done one of these and I know products have changed. If you have a suggested part that you feel should be added please provide as much information and a link to the manufacturers website for that part.
Disclaimer: This is in no meant to be completely factual posts and all viewing are encouraged to research and ensure fitment on your vehicle.
OS-5
- OnStar® Radio Replacement Interface for Select 29-bit LAN General Motors Vehicles with or without Bose Sound System. Retains OnStar® system functionality and the Bose factory-installed amplifier (if present) when the factory radio is replaced in a 29-bit GMLAN vehicle. Generates all safety warning chimes and audible turn signal indicators.
GMRVD - Overhead LCD Retention Cable for GM Vehicles With Rear Seat Entertainment. Provides an audio/video signal output from a factory radio to an aftermarket monitor. Also for use with a radio replacement interface to retain the overhead LCD monitor and IR system.
95-3305 - GM Dash Kit
GMOS-LAN-01 - GM 29 Bit LAN Data w/RAP ACC & Onstar & chime retention
GMRSAV
- Factory rear seat entertainment retention harness for GM LAN29 vehicles
GMRSAV-2 - GM 12+ w/Nav RSE A/V Harness
BACKUPCAM - Factory back up camera retention harness for GM LAN29 vehicles
BACKUPCAM-2 - Factory back up camera retention harness for GM LAN29 vehicles with factory navigation
Maestro RR - Web-programmable radio replacement interface for integration with factory systems including steering wheel controls, media player, hands-free telephone, voice commands, and satellite radio modules. Also displays vehicle information (performance gauges, climate controls, battery voltage, check engine codes and more) with iDatalink-compatible radios. Basic radio replacement features also available with non-iDatalink-compatible radios.
AVGM5 - Provides A/V connections to the factory video screen and A/V input port.
This is an on going thread that I will update as I can.
yates ™
yates ™
Iowa
Does anyone have a link to a TYF thread showing step by step instructions of any of these installations? Thread starter will get all the credit as the thread will be linked from this thread.
AppocAlexx
Darth Appocalexx
Abilene TX
So if I do not have OnStar, Nav, Bluetooth, steering wheel controls, rear controls and not sure on amplified system or not, but pretty sure i dont have it, then i can get this wiring kit http://metraonline.com/part/LC-GMRC-LAN-01 along with the antenna adapter? Or is there another wiring kit i will need along with anything else to install an after market stereo?
Ob1hybrid
Really wish someone would give some insight on the hybrid versions. I'm sure there's one insane person out there that upgraded their Hybrid..come out wherever whoever u are
Ob1hybrid
I don't know and I can't find ANY info on differences, losses, and/or how tos on upgrading hybrid nav systems. Just a couple of don't do it because I heard someone say don't it.
yates ™
yates ™
Iowa
Let me know what you find out so that I may add any information to the list.
Draganjr
Good afternoon. My first time here.
I have a 2009 Yukon SLT-2 with Bose, On-Star, XM, rear radio. I want to only upgrade the Headunit. How do I keep the factory Bose, rear radio and On-Star stuff? I looked there the above info but could not find where is talked about Bose.
Thank you
David Ragan
yates ™
yates ™
Iowa
Thank you
David Ragan
OS-5 - OnStar® Radio Replacement Interface for Select 29-bit LAN General Motors Vehicles with or without Bose Sound System. Retains OnStar® system functionality and the Bose factory-installed amplifier (if present) when the factory radio is replaced in a 29-bit GMLAN vehicle. Generates all safety warning chimes and audible turn signal indicators.
Draganjr
Does anyone have experience with the iDatalink Maestro ADS-MRR /
GM5+
Thank you
David
YukonCrazy
Raleigh, NC
I would like to replace my OEM radio with something that has a screen. I don't have NAV and I don't have a backup camera. I would just would like it to look better than this.
This thread is good, but I am still not sure how to get to a replacement. Obviously I need a new head unit and probably a harness.
Do I need to find a used head unit out of another NNBS in for sale forum? Do I need to purchase a head unit that is compatible with GM? Not sure where to start.
Drunkinmayhem
Is there a one stop shop kit? I have an 07 Tahoe LT. I have Nav, Bose, rear DVD entertainment no phone on the steering wheel and it has a back up cam. I have the Sony XAV-AX100 CarPlay head unit
yates ™
yates ™
Iowa
Any brand preference? Basically pick out a double din TV you line with the options you want. Get a mounting kit when you order it. I would get that maestro wiring harness as, I believe, it is plug and play.
boydcustom
Thank you. On order.
I just installed these in 2013 Yukon XL. Bose. No Nav.
Works fine. I installed Pioneer 1300NEX.
PROS:
Super easy.
Works
The OBI stuff it kinda neat
CONS:
I did have to use the supplied microphone from Pioneer. The factory mic does not integrate.
I had to use the Metra supplied speaker for the chimes/blinker sound.
Hard to fit all the wires in Dash
There doesn't seem to be a way to connect the backup camera to the Pioneer screen, but it does show the park assist zones
Overall:
I'm happy with it.
Buford bubba
