Cattivo
The Concrete Jungle
TheAutumnWind
Installing a circuit breaker is silly IMHO...the ANL fuse in the link is the correct way of doing this mod:thumbsup:
Also if you're NOT using copper cable, I recommend applying penetrox on both ends before installing them into the fuse
no reason to not use 100% OFC...
Cattivo
The Concrete Jungle
Now a days aluminum is a lot less expensive compared to ofc... I would still apply penetrox on both ends regardless, the ANL fuse is located in the engine compartment which will be exposed to rain, snow etc. which will show signs of oxidation over time
TheAutumnWind
OFC Advantages
  • Increased Conductivity to Carry More Current to Your Amplifier
  • Reduced the Strain on Your Vehicle’s Electrical System
  • Increased Corrosion Resistance
  • Decreased Maintenance Costs
  • Improved Heat Absorption
I'd much rather run 1/0 100% OFC then CCA 3/0. Cost is the same or less... performance would be about equivalent. "Welding wire" is cheap. I spent ~$25 on my 1/0 100% OFC big 3/4 on my nali.
Sure you could get Uber wire from some supercool car audio company with pretty colors and spend way more I guess.
Cattivo
The Concrete Jungle
OFC Advantages
You're 100% correct brother, the point I'm trying to make is, anyone here thinking about doing this mod and is NOT running ofc should indeed reconsider...copper wiring oxidizes rather quickly when exposed to outdoor conditions, that's why I recommended using penetrox
TheAutumnWind
You mean CCA?
I used marine grade dual wall shrink, and covered anything exposed with paint to protect against corrosion. Penetrox looks like a good option for CCA, but I'd highly suggest using 100% OFC instead.
jarydM
Lost in the Woods
Tennessee
oh boy you are gonna love the ride improvement
sway bar links might be toast too? Might as well do the bushings as well. Sometimes those dont look super warn but they are ovaled out on the inside.
Back to these jounce stops, because we haven't talked about them enough, but is there any reason to buy anything other than the z71s (or is it this one)for a stock ride height? Mine haven't touched since I owned the vehicle, and don't look over-worn.
the old post about the stops, someone had linked to Timbren Ind for aftermarket ones, but I can't seem to find one for our trucks on their website now. Unless there is a universal that just didn't show up in the search.
**EDIT** nm, now its working.
Cattivo
The Concrete Jungle
You mean CCA?
I was actually referring to ccwa...ofc 1/0 copper is what should be applied to the big 3 mod. Anytime you go from copper to aluminum you risk oxidation is all I'm saying hence why I suggested the penetrox
TheAutumnWind
Yeah I'm 100% on board with that. I was just confused by your useage of the word copper I guess. CCA= copper clad aluminum and OFC is oxygen free copper so there is copper in both...carry on good sir.
Cattivo
The Concrete Jungle
I'm not really too familiar with jounce stops and what their actual purpose is...are they for lowered, stock or lifted trucks? or all of the above?
Cattivo
The Concrete Jungle
It's an industry term I use on a daily basis, sorry for the confusion brother
TheAutumnWind
I think the z71's are a touch stiffer then the other ones that look like a beehive.
I know your not lowered but...
I ran these when I was lowered ~1.5" with a crank and they were perfect:
https://www.amazon.com/gp/product/B003EP2OD4/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
worn stockers vs those.
FYI FOR those of you reading along I had to cut off the bolt on the bottom of these, but then they fit right in just like stockers.
jarydM
Lost in the Woods
Tennessee
Yeah, I'm stock height, with plans to go up about 1-2" but the lift is a few years from now. I suppose the best way would be to get under there and measure the difference and buy one that is that size, correct?
TheAutumnWind
For stock height id just replace with oem ones. z71 or beehive style depends on whether you want a slightly stiffer ride or not.
BADRIDES
Conedaddy
