20x10 on a level
dreww2001
STL
So my plan was to buy some 20x9 Fuels, there is a guy who will sell me his XD Heists and they're a 20x10 im planning on running the Open Country R/T because thats what hes already got on them and they were what i was already planning to go with the size are 305/55R20 Q what would I need to do to get them to fit? Im going with the Rough Country 2" Level
02Burgundybeast
South GA
You might scrub a little on the bottoms of the valance when turning but them only being a 10 wide you might be ok.
01Konvict
Boats n Hoes
Raleigh/SML
HA that wide of tire on a 2". You will need to trim bumper corner and maybe small norcal mod. I would do front 2" level and zone 2" body lift. This would make the offset and height look perfect.
dreww2001
dreww2001
STL
Would I need to mess with the auto ride in the back with a body lift?
dreww2001
dreww2001
STL
Could you also send me a link for the auto ride extenders I just went on zones website and they said I need the extenders and I don't know where I would find those at.
01Konvict
Boats n Hoes
Raleigh/SML
If you have front magnaride then you should get the suspension maxx front 2" kit with plate to set ride height controls at normal level. Body lift will do nothing to auto ride. It's a good 4" kit with 2" front level and 2" body.
dreww2001
dreww2001
STL
So I don't know a lot about the suspension so I should go with the zone 2,4 body lift and add another level from suspensionmaxx?
01Konvict
Boats n Hoes
Raleigh/SML
No any 2" front level will work but if you have ride height rods for electronic dampening up front then I would get suspension maxx since their kit has brackets for the level. Then order a 2" zone body and done with total of 4".
dreww2001
dreww2001
STL
I'm sorry I'm asking so many questions or not getting it but are these the two kits you recommend
01Konvict
Boats n Hoes
Raleigh/SML
Thank you! Do you know of anyone who's done this and has pictures?
Not the total kit only seen a few 3" which look garbage but a 1.5 or 2" isn't bad because the steps still cover the frame. As far as level plenty have done it just not sure where pics are of the front bracket for auto ride. Think some guys in 15+ section did the front kit.
dreww2001
dreww2001
STL
Thanks for your time!
dreww2001
dreww2001
STL
On Zones website it says ill need to extend the ride height sensors are you sure i won't need anything to extend it with?
01Konvict
Boats n Hoes
Raleigh/SML
That's for the front but if you get the other kit I posted it has the part to lengthen or should I say set the ride height sensor at correct height
dreww2001
dreww2001
STL
That makes more sense thank you!
ta07hoe
They should fit with some trimming, if these guys run this then you should have no problem. I'm going with 20x10 -19 on a 2 inch level once winter is over
01Konvict
Boats n Hoes
Raleigh/SML
I guarantee that both those yukons with x12 and x14 on level kits can turn lock to lock! Yeah they trimmed the front bumper but you would have to large norcal at then still rub. x10 should clear with minimal if any trim on the 4".
CrackerJack135
