Replace entire AirRide System or Convert to Passive?? - 2003 Denali
bldn10
Memphis
I have a 190000 mile '02 Tahoe w/ Z55 Autoride and G69 level control and am getting it ready to tow for my first time. A 3000# car on open aluminum trailer, max 4500#. As far as I can tell the systems are totally shot - no warning lights, no nothing. The shocks appear to be the original Delphis. I talked to a tech guy at Arnott and he said the components are only good for about 80,000 miles and that I need to replace the shocks and compressor. Does that sound right?
I frankly don't think I really need the Autoride dampening but what about the level control?
If I replace those parts is it certainty the system will work? I.e. isn't there some electronic control that could be bad too?
adventurenali92
Big Bear Lake, ca
@bldn10 , it is my understanding that the entire system functions as one. Auto level and dampening occur together. Not independently. If no air is being pumped into the shock then the dampening and leveling aren't happening. So if you replace your shocks and your compressor, the entire system will function as it should.
bldn10
Memphis
But somewhere isn't there a "brain" that takes in the sensor inputs and "decides" what to do? If that doesn't work, I'm not sure that anything will.
FWIW I also have 2 stored fault codes:
P1571 TCS PCM Circuit No Frequency
P1689 Delivered Torque Circuit Fault
There is a Suspension Control Module but it rarely goes out. As far as damping, you can buy the shocks with or without. Arnott sells a premium rear shock that just has air bags without damping. It uses resistors to fool the SCM into thinking it has damping. I am running those and their compressor.
PS you won't be able to read codes in the SCM without a Tech II or Snap-On equivalent.
adventurenali92
Big Bear Lake, ca
@redrocket, I've heard alot of horror stories of guys buying the Arnott shocks with the resistors and that the resistors always burn out and then the service ride control or suspension light always comes in. How are yours holding up?
I had problems with the fronts but I think it was because my cats were clogged and it was making the manifolds hot which made the resistors fail since they were right next to them. Regardless, I bought some wire wound heavy duty ones and wired them in place. I did all 4 just to be safe.
kebm
I just replaced all 4 autoride electric (not air) shocks on my 2003 Yukon xl 2500 quadrasteer.
For the front I put in Monroe reflex, rears are monroe load adjusting coilovers. I did not put resistors on the wire ends, and have not had any warnings on the dash yet. I also replaced the front sway bar links and mount bushings with energy suspension polyurethane. A short test drive proved excellent results. I chose the rear coilover shocks to help with tongue wieght while towing.
The autoride shocks were toast, the only thing they were good at was making clunk and clank noises lol. I dont think I will ever go back to autoride shocks, but I left the sensors in place.
TheAutumnWind
Huh... I had no idea that the Yukon XL's had the quadrasteer option. 2500 only? Anyways happy to hear your shock replacement was a success.
kebm
It was available in the suburban 2500 as well as the yukon denali(1500). I have seen it on extended cab and double cab trucks, too. Too bad they never made an avalanche with it. I would love to have a duramax/allison quadrasteer avalanche!
I dropped the yukon off to have the a/c repaired today, and the service ride control message was on. I guess I will be getting some resistors...
TheAutumnWind
Yeah I have only ever been aware of it on the trucks. Do the fenders flare differently on the kon or burban with the quadrasteer option like they do on the trucks?
kebm
The rear quarter panels are the same as non quadrasteer sub/yukon, but the plastic wheel flares are wider with marker lights.
TheAutumnWind
Learn something new every day. Must be fairly rare.
bldn10
Memphis
Well, yesterday I replaced the pump and rear shocks w/ Arnott 2715s but I'm not sure if anything is working. I disconnected the bottom part of the RR sensor and moved it to mimic a load but the pump did not come on. Then I started thinking it might take awhile, or maybe the truck needs to be moving. Is there a way to confirm if it is working or not?
You can remove one of the air lines from a shock, let any air out and the rear should settle a bit. Then reconnect it and start the engine. You should hear the compressor come on and the rear should raise a bit. If it doesn't, something is wrong. Mine had a rusted ground wire at the compressor. Also check if your RTD and STUD1 fuses are installed and not blown in the under hood fuse box.
bldn10
Memphis
No air came out so shock did not move. The pump has yet to come on. I called Arnott but they were not much help - said could be sensors but they have to be checked via computer.
Did you check the fuses I mentioned as well as the ground wire from the compressor to the chassis? And no, Arnott can't help over the phone. I doubt it's the sensors, it's probably power or ground. It might be STUD 2 instead of STUD 1 on the fuses. Check both. And definitely RTD.
bldn10
Memphis
Fuses are good. There is no ground wire, I assume it is grounded case to frame.
Mine has a ground wire in the harness up a ways from the compressor that has a lug that goes to the frame. It was corroded at the lug and you couldn't tell it wasn't making contact until I pulled on it and it came loose.
TheAutumnWind
It should have rubber bushings on both ends... Might make it hard to ground case to frame.
Is there any power wire running to it at all? I seem to remember there being one.
Edit: Nevermind were talking compressor, not the shocks.
Bob LaFord
