Madgrty
What size battery will fit in the secondary tray Underhood? Dimensions wise, I just purchased the secondary battery tray but can't find anything showing me dimensions. Thanks!
Went to buy that very same battery today at my local batteries plus and they stopped carrying them due to almost every one of them being sold were returned for warrant purposes. And northstar was very stringent on the returns. I would be cautious buying them at the moment.Group 78 or 34/78 was the biggest I could fit.
That's the same size as the starter battery.
78 = Top terminals, 34/78 = both. Both of my batteries are 34/78's.
I spent weeks looking to see if there was a way I could put a bigger battery in there but as near as I can tell, 34/78 is the biggest that will fit. I also got the X2 battery which has the highest amp rating of any 78 or 34/78 I could find: 68ah which is quite a bit more than the standard 78 which is about 55ah.
Very strange as i cant find a single bad thing about them anywhere.
I was planning on ordering an XS Power battery online (only place to really get them) but the only thing is I need the dimensions more than what group it is since it's a car audio battery, they are different apparently
It's still showing up on their catalog:
https://www.batteriesplus.com/battery/rv/deep-cycle/12?q=group 34/78
Maybe try a different Batteries Plus. Could be they're just out of stock and want to sell you a different battery?
There's also the very similar Odyssey which is available at about the same price from a number of sellers including Amazon.com:
https://www.amazon.com/Odyssey-34-78-PC1500DT-Automotive-Battery/dp/B000TCTD3Y/ref=sr_1_1?ie=UTF8&qid=1480603106&sr=8-1&keywords=odyssey+group+34/78
I believe the Odyssey is also rated at 68ah. In fact, I think the main reason I went with the X2 over the Odyssey was that the local Batteries + wanted almost $350 for the Odyssey and I wanted to pick up a battery in person rather than deal with Amazon.
If you do go to Batteries + make sure you get a coupon, I think there's a 10% off coupon you can get for picking it up locally - basically it will cover tax.
Our state (CO) will sock you with a $7 core charge if you buy a battery without having one to turn in so I put a message out on a local board asking if anybody had an old battery laying around. I was able to find someone a few blocks away within 10 minutes and picked up the battery at his house so I didn't have to pay the core charge (they don't care whether the turned-in battery is of the same type as the one you're buying.)
The only batteries they seem to carry on the shelf now are Duracell, which are made by Deka which is still a great battery made in the US and with a 4 yr replacement warranty. I ended up going with their 34/78 AGM and like I mentioned above, they marked it down to like $145 and took my old POS interstate out. It doesn't have the capacity or the CCA that the X2 has, but I personally don't need it in my situation. When I finally complete the 2nd battery install, it will be more than enough for my needs.
Yeah it's most like the same battery I have along with the Deka Intimidator. You notes here are exactly why I wanted the X2, but Batteries+ comments and no longer carrying them turned me away. Just wanted to make others aware to ask around before ordering them.My starter battery is a Deka as well (Sold though O'Reilly auto parts under the name of "super start.") 55ah, pretty decent depending on what you're using it for.
Since I run a fridge in the summer time I need a powerful battery. I think the X2 has a 5 year replacement warranty, and I carry the receipt in my glove compartment (although the guy at Batteries + said that since I was "in their system" that wasn't really neccessary.) Since Batteries + is all over the US I figure if I have an issue I can take to any batteries + store for a replacement.
Side note, so you were able to squeeze that X2 34/78 into the secondary tray? It fits ok in there with the top terminals?
