Looking at 08 Yukon 6.2 AWD need input
Jbird
Sold my diesel to get back in a tahoe. In my search i came across a good deal on Yukon Denali. Its just over 100k miles. Has the 6.2 and is all wheel drive. Which are the two things im worried about being as ive only had 5.3s that were 4x4.
Any bad experience with the AWD?
What about the 6.2 motor?
Any input is welcome
Jbird
Jbird
Anddd just from reading into the other similar threads. I can say im already leaning towards paying a little more for the 08 tahoe i had picked out. It was a private seller a fewer hours away which makes it a pain to work the deal but it only has 82k miles and seems to be in immaculate shape. I just worry about all the fancy stuff on the yukon giving me problems
93blkongreenpro
The awd doesn't give a lot of issues and the 6.2 is just as bulletproof at the 5.3. Some say they even get better gas milage out of the 6.2 and of course, they love the extra power on tap. I wish I would have paid more and got a yukin denali over my yukon slt.
Sent from my SM-G935P using Tapatalk
Jonah52
Senor ******
Cleveland
400 horse in the 6.2. Definitely notgas station friendly. But if you can afford it then you probably aren't worried about the 12mpg you'll get with the awd. Check diffs. If you hear a clunk it's probably just a slip home that needs greased. Also the Denali and eskys came with 6 speeds which are way better than the 4 speed found in earlier tahoes/burbs. You'll get more options with the Denali and the resale is higher. I'll never buy a 5.3 again, the 6.2 is a monster.
Jbird
Jbird
What about the air shocks i know people talking pretty negative about them. I put a lot of miles on my last two tahoes and plan to try to do it on this next truck. Trying to avoid buying anything with that cause unwanted problems. For example air shocks that i dont need because i never tow anymore
Jonah52
Senor ******
Cleveland
It's a necessary evil if you want an LTZ/Denali/esky
My compressor went out and I got the dealership I bought it from to fix they ride better but cost more. Just check for leaks.
The problem I a whenbyou blow a shock and the compressor continually runs and burns itself up. Just be on top of it. If they go out you can do a passive conversion. But they ride really well, that's why there there.
Jbird
Jbird
How does the awd work? Is it always engaged or engages when rear tires spin or what
Jonah52
Senor ******
Cleveland
There is a 60/40 power ratio. 60% of the power goes to the back, 40% to the front. Limited slip rear. All four wheels always get power.
Jbird
Jbird
It that doesnt cause problems on up closer 200k miles? I would like to level it and bump up tire size eventually also worried how that effects it
Jonah52
Senor ******
Cleveland
I'm at 165 no problems my 05 debali 170knno problems. My 07 was leveled with 33x12.50x22 and no problems. You'll be ok don't gonhigher than 2" in the front though, you'll be too close to your droop stop above 2"
Jbird
Jbird
Well now i really dont know which way go. Lol
08 tahoe lt3 5.3 4x4 82k miles or 08 Yukon denali awd 6.2 116k miles. Tahoes 20 yukon is 18
Jonah52
Senor ******
Cleveland
Yukon. No questions asked. More options, viewed higher model than a ltz. 6.2 is worth it all day.
M3kanic
I traded a 10 Tahoe for a 10 denali xl awd. I get better mpg because my foot isn't always on the floor. Best decision I ever made.
Jbird
Jbird
Hmm hope it dont turn around bite me. I dont want to have to redo the front end on this thing anytime soon
Jbird
Jbird
Good deal looks like im gona go for it. Ill post a pic tomorrow
David Upshaw
I have a 2010 Yukon Denali with 150k miles owned since new. I would buy another in a heart beat . The 6.2L is an awesome engine ******* fuel if you are mashing the gas all the time. I consistently get 19 mile per gallon on long road trips I get 21 miles per gallon. The truck is completely stock. No issues with the AWD or the air ride suspension.
DO NOT neglecte the maintenance and you will have a flawless vehicle.
Sent from my SM-N910W8 using Tapatalk
Jbird
Jbird
Jonah52 what leveling kit did you use and how much did u have to trim
Jonah52
Senor ******
Cleveland
All depends on offset. Here's the set up i ended with after screwing with like 4 different kits
2" front spacer of your choice
1.5" rear spacer of your choice
I used eBay
I removed my running boards.
Then factory 20's with 275/60/20.
That's 33x10.8 and won't rub and don't need trimming. It is also same load rating and ridesnjust as well.
I did have 22x9.5 fuels -19 offset and 33x12.50 Toyo Mt. I could barely turn, it road like crap and ripped out my liners.
Do the suggested spacers I listed and your rear will be 1" higher which will visually look level. My truck was .5" higher rear and it visually looked saggy. Trust me on those spacer sizes if you want it to look healthy.
PM if you have more questions and I can shoot you a text :)
ASG-MikeS
