Sway Bar Links After Spacers -Options/Pics
whitey hoe
So after I lifted my tahoe I noticed the steering was sloppy particularly in the rear. The way i would describe it as "whipping". The back end whipped back and forth similar to a snake when making any movements at speeds over 50mph. After looking at the sway bar links I noticed they were at a horrible angle. I started to research tahoe sway bar links and noticed they were the same as jeep wrangler (JK). After taking measurements and contacting warrior products I confirmed the JK 3" sway bar links were the solution. The handling is much better. Pics and angles are below:
I read a lot of forums on whipping when spacers and keys are cranked.I've found that with spacers,2 1/2 keys cranked,extended links front and rear,longer new shocks and of course good tierod ends and such,the ride is great,no whipping.Must have all the puzzle pieces for a key lift.Hope this helps to all key lifters in the future
Jonrobinson84
Is it still cheaper considering all those components to do the key lift and spacers compared to a out of the box lift from a manufacturer?
whitey hoe
I believe it's cheaper and also allowed me to get top grade shocks w the savings
whitey hoe
Got links for parts ******?
Sent from my XT1585 using Tapatalk
I researched all my parts from this forum,everyone was great w their knowledge.3 in extended rear sway links for a jeep tj from eBay,cognito links for the front,not sure if they were from eBay or a thread from here.wish I could b more help but all the info is in these threads
VABURB
Chesapeake,VA
i have all the goods on the way to do keys, spacers and bilsteins. This is first im hearing of extended links definetly gonna order some anybody have web link for front setup?
ATIII
Brighton, CO (Denver)
I ended up using the Cognito HD sway front sway bar links. I broke 2 sets of Moog ones.
JeffK
