SQuEAKY DOORS!!!
flyinghigh54
San Diego
Anybody have squeaky door hinges? Accompanied with some bumps cracks and moaning sounds?
I have traied wd 40 superlube lube w ith teflon sealant. I have put grease in areas that seemed like they were squeakin......... idk is it just a thing to live with?
Sounds like my door is gonna fall off
DenaliAK
Colder than you
Alaska
One of my doors squeaks annoyingly, but it's the weather stripping up top that does it. I just put up with it because if I don't I'll probably screw up the seal and end up with a puddle in the back seat.
HighRollerRich
i do, ive been wandering what the part is that needs to be replaced. i can tell the door is starting to sag, as in it doesnt want to line up wiht the striker bolt.
gtbigup01
Columbus, GA
Yeah had the same problem and it wasn't actually the door but the weather stripping on top. A little but interior dressing whatever you currently use will fix that problem.
I did the same thing and sprayed WD-40 and the squeak was still there WTF, after a careful examination i realized it wasn't actually the hinges like i thought
Nickleahy23
Portage/Menomonie, WI
yup both of my back doors do it..the weatherstripping and the hinge..its more a grinding on the hinge..ive tried a ton of different lubes for it and it doesnt really help..o well
flyinghigh54
flyinghigh54
San Diego
ok i see. yea I know its not the stripping I have dressed them all up. I have closely examined it for a long time now and it is def in the hinges somewhere......... ill let you know if I ever figure it out thanks
rdtahoe
NJ
The top weather strip needs to be siliconed as the other folks have mentioned. That was one of my problems and it works. The other part squeaking was the part that goes into the door through a rubber boot that you will see there. Pull the boot off, and shoot some lithium grease onto the shaft that goes into the door, and also lube the hell out of the little roller wheels in there, mine were squeaking like hell. Lubricate the shaft and the rollers. That keeps mine quiet for a few months or so and then I need to do it again. Yeah, I also do the hinges.
Tribalbreak
WARminster PA
last year i had a squeaky hing... i used some white lithium grease.... from a tube not a spray can... got it on all the moving parts and the door quieted up quick... its been good since but i wont be surprised if it happened again now its getting cold again...
flyinghigh54
flyinghigh54
San Diego
ok yea it seems like it is coming from the part that goes inside the door! ok Ill try it tomorrow when it is light out again thanks for the tip
Durobans
