rear end gearing
Archtoker420
Archtoker420
I be been looking into a bb tune but have to wait till income tax so I have enough extra money. What exactly is a stall converter? Don't think I've heard of that
SUBURBIAN
All Chevy
Yes, you will benefit from a lower gear ratio, and no, you don't need 35" tires to do it. The taller gear will lighten the load on your engine and drive train and mathematically change the number of times the axles turn in relation to the number of times the drives haft turns. Disregard anything anyone else tells you about this. It's not opinion, it's MATH.
A stall converter is actually called a torque converter, not a stall converter. All torque converters have a rating called the stall rating. It is the engine rpm where it begins to couple the engine and transmission, as the torque converter is the fluid coupler between the engine and transmission. A factory torque converter has a very low rpm stall rating. Performance oriented torque converters stall at a higher rpm. A higher stall rating benefits a combination of engine transmission tire size gearing and weight by bringing in the engine's power at the right rpm to launch the vehicle based on the engines torque peak.
bai78
Surviving
Dallas, TX
In the end how much $$$ are you willing to put into the fun truck?
Weigh thr options and choose your mods wisely.
Archtoker420
Archtoker420
In the long run I don't mind putting some good $$ in. But right now just looking for some what cheap. Would a 4.10 rear end be worth it?
Archtoker420
Archtoker420
So if I did change the rear end to a 41
.10 should I look into an upgraded TC too?
Archtoker420
Archtoker420
OK cool. I guess I'm gonna start researching and looking for parts and hopefully get that done eventually. I appreciate everyone's input on this. Because I'm trying to figure it out on my own and yall are the only ones I can ask for help/advice lol
bai78
Surviving
Dallas, TX
Personally you should boost it, tune it, and go from there. That would net the most gains for the least amount of mods.
You'd need top end and higher gears once the 8-10lbs of boost kicks in.
Don't take our word for it. Seek out others in your area and get first hand experiences.
Archtoker420
Archtoker420
I've been looking for something to boost it and someone showed me procharger superchargers that would fit I think and I've heard other people talk about Whipple and wynjammer. Every time I try to look on summit or something I end up on weiland which says it fits my 99 but I need a carb and my truck is injected. So I get pretty confused in how to go about all that
bai78
Surviving
Dallas, TX
Google this kit number for your application.
1GH212-SCI
Check if Vortech has an application for our old trucks.
Archtoker420
Archtoker420
1GH212-SCI
I Googled it and damn that's pricey lol. Is there anything cheaper? And where would I che
1GH212-SCI
I checked out that procharger and that's pricey lol. Went to vortech website and didn't see anything under a 2001. So it looks like I got a lot of saving up to do.
bai78
Surviving
Dallas, TX
Search around as you can always pickup a used kit. I bought mine for less than $1800 or so if I recall correctly.
I was just vigilant as well as patient.
Archtoker420
Archtoker420
Well that's a hell of a deal cause new was like 6500 lol. I'll have to keep an eye out. Where did you find yourself at
Archtoker420
Archtoker420
I looked at a wynjammer and it's pretty cheap brand new. Somebody on here installed it on a 99 Tahoe and had good things to say. I heard of putting a Whipple on a tbi but not exactly sure what that means? Is it diff from SFI
bai78
Surviving
Dallas, TX
TBI = throttle body injection
Yes, different from the MPFI/SFI '96 - '00
SUBURBIAN
All Chevy
It is a good deal of work to swap away from the vortec injection and computer setup. Not cheap either. If you really need a power adder the wynjammer kit is very straightforward.
moto
