As far as the install, in theory there is not much to it, but somehow it took me all weekend and a bit of follow up work, not even counting the time it took to align it afterward (I did the align myself). I'm kind of slow doing things I am unfamiliar with though. If I did it again it would be much quicker.
Bolting the spindles on is pretty straightforward. However on the brake lines, there is a bracket that secures the line to the spindle. The bracket is clamped onto the brake line. You have to rotate the bracket 180 degrees and move it down the brake line a bit. It was fairly difficult to do that, but by spraying the line with silicone spray I was able to work it to the correct position. Then you want to check to make sure that the brake line is not tight at full extension and wheel turned full left and full right. Move the line on the bracket as needed to address that. I also checked with the wheel compressed to make sure the line wasn't hitting anything; no issues there.
My Tahoe has ABS, so I had to re-route the ABS wire and check it at full extension as well.
Also after I installed the spindles, my alignment was way off. Even if I had a shop do the alignment, I would have set the toe before even driving it.
Good luck, it's a significant job, but nothing like lifting a 4wd!
