Want to lift!!!
07warwagon
@09HOE4x4...where are you located? I have a 4" Rancho lift kit I'm looking to sell
Mgyver1
Las Vegas
If you're just looking for show and no go then a spacer lift or some 6" Rancho lift would work.
If you want to use your vehicle offroad then I would look in to better quality products such as King, ICON, etc, that will give excellent offroad performance with larger diameter shock bodies that will help with heat build up.
King has coilovers that will give 2.5" - 3" of lift with claims of no CV issues
http://downsouthmotorsports.com/i-1...chevy-gm-suburbantahoeyukon-1500-4wd-2wd.html
And ICON has a similar product that provides 2" lift and clears 33's:
http://www.iconvehicledynamics.com/...7}Tahoe-0%2d2"-Suspension-System-Stage-1.html
09HOE4X4
Centennial, CO
Well I ended up putting together a kit from the Rancho quick lift loaded and a 2.5 spacer and then the box 1 from the BDS 4" lift w/ knuckle. Then did a 3" spacer on the rear. This got me 4.25" in the front and 3.5 on the rear. It gave me a level stance with 9" between top tire and wheel well. I also went with Xd revolvers and Nitto Mud Grappler 33/12.5/20.
The set up looks awesome, When I get home this time I have a few finishing touches and then I will post some pics.
truckn02
