Up in Smoke
Texan
Texas
As I left from work, not even a mile down the road, smoke starts coming from top of dashboard. I pulled over and ripped my dash cover off and abroken piece of dashboard. I had already shut of the engine. The smoke was coming from the cluster box, white and black box. The smoke eventually stopped and I let it cool down for 10 minutes. Started it back up and no more smoke. Then I noticed the message box and gear selector box were blank. The backlight is working and the needles are too, just the message displays aren't.
Do I need a new cluster or can this be diy fixed?
Texan
Texan
Texas
I was posting thru my phone, sorry for the vague message. So, what happen was the cluster box started smoking and smelt like burnt plastic/electronics. My dash was already cracked/broken, so when the smoke started puffing out, I ripped off my dash cover which is held on by Velcro and removed a broken piece of the dash to see where the smoke was coming from. The smoke eventually stopped, but when I started the Tahoe back up, the DIC and gear selector display were no longer working. I never had any problems with it before. I've been doing some researching and I guess the circuit board probably has a fried component.
KBones
Wow that's frustrating. I'd just buy a sweet aftermarket cluster and check all connectors on the back. Sounds like something internally went wrong
Texan
Texan
Texas
Seemed easy enough to replace the MOSFET, so I bought one for $9. Thanks to my cracked/destroyed dash, it was a little easier to remove the cluster. Opened the sucker up and.....the MOSFET was completely TOASTED!!
I tried very carefully to remove it, but the solder pads were burned off, so I could not repair it.
I contacted a few ebay cluster repair people, two said they could not fix it and one said they would attempt to repair, but it would be an additional $50 to the regular price with no guarantee.
Decided to just reinstall it for now, just annoying to not be able to see the mileage. The gear selector display works but is very faint, only can see at night. I'm surprised nothing else was damaged.
golavaman
