Traction Active
95escahoe
This morning when I left for work took off from a stop sign and got the Traction active message stayed on for a few seconds and then it was fine, no other odd sounds or issues, from looking around it looks like it might be a bad hub or wheel speed sensor? Anything else it could be, and only the front wheels have the speed sensor correct?
Sasquatch
Orange County N.Y.
There are sensors on all four corners.
I had the same thing happen and it was the front speed sensor, I was still under warranty at the time and the stealership replaced the whole hub. I`m not sure about how they figured out which one it was.
95escahoe
95escahoe
Thanks for the info, just had the front brakes done last month and had them check the hubs and they were good so thinking it's a sensor, it was 34 in the morning tho maybe there was a slick spot on the road, I think I read with a handheld scanner they can tell which one is bad
24tahoe04
