The dancing gas gauge :(
billowred
After this last fill up the needle started doing going all over the place. I linked a video (sorry for crappy quality) to show what it's doing.
http://www.youtube.com/watch?v=IKtFX61aBZw
If you have any suggestions for a way to make the gauge more accurate than stock I'm in.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
if that was after filling up the tank completely i would say it is the sender that finally gave out but to troubleshoot accurately i need to know what year you have.
kaoticlife
Port St Lucie, Florida
wow mine dances but thats more than mine does...mine just vibrates and shifts back and forth a little bit..oh only after half a tank..:gay:
billowred
billowred
Yea that's exactly what mine did till now.
SunlitComet
OBS Jedi-Do Good
you need to get a ohm meter set for 100 ohms on the purple wire at any point from tank to cluster and to ground. if needed take the cluster out and undo its connector and use alligator clips or something then drive it again to with the ohm meter response to see if it is still wild. for reference when tank is empty it should read about 0 ohms when empty and 90 when full.
Phone Man
Long Island NY
Could also be the "hummingbird" effect from these gauges. Mine vibrates also. Its is caused by the dampening oil evaporating out of the stepper motor and the pwm signal that the ecm sends. In the link below there is a detailed explanation and a solution if yours is a gauge issue.
http://www.pacificp.com/forum/viewtopic.php?t=8413&postdays=0&postorder=asc&start=320
I have changed my fuel pump and the gauge has remained the same. Maybe yours is a sender issue? It usually occurs just out of the blue. There are sites that sell the stepper motors but they are a different type and are for the 2003 and up gauges.
billowred
billowred
Damn you guys know your sh*t! I'll take a look Friday when I have more time. Thanks for all the help.
SunlitComet
OBS Jedi-Do Good
for the 1996 year the Pcm has no role in the fuel gauge operation. In fact it did not get "wired" in until 1999 model years.
DirkAFD
OK
What did you figure out on this? I have a 97 that's doing the same thing but WAY worse. If there was a Full and Half mark, mine could hit it.
Smokin Denali
