Suburban vs Escalade rear springs
residentdud
Petawawa, Ontario Canada
Hey guys,
I'm raising my burb back up since the ride on my lowering springs is way too rough...
Question...are Escalade springs the same as the Burbs OEM springs? Ride height etc?
I installed the Escalade springs and it seems jacked up in the rear...
Thanks
NathanJax
Vacation Nathan
Administrator
Jax, Fl
They all use the same lowering kit, so I'm almost positive they're the same OEM spring.
Goodinblack
I Like Tacos
Dirty South
I think that though they may like the look identically same......they are different because they may be tuned for auroride
yates ™
Resident Apple hater
Iowa
Maybe be a silly thought but have you given them time to settle?
Gzes
the drifting 2dr
Wichita tx
I agree with derek. It should take a couple days to settle right if not then thats why it looks a lil higher
kses123
kses123
Raleigh, NC
The springs are different in the rear between the autoride and non-autoride models. They are also different if you have a Z71 model, as well as a Police model.
R
residentdud
Hmmmm...
If they were made for an autoride system, wouldn't they be softer? (lower ride)
Can someone tell me the measured height of a stock set?...I'm getting 38-1/4" from ground to wheel well...
35" - front
38-1/4" - rear
Long story short - I was removing the 2/3 lowering springs, I couldn't seperate the front strut/spring (spun the shaft in the strut) So I bought a complete set (used) from the wreckers...
Seems very high...feels like I'm sliding into the dash when driving...
Thanks guys!
yates ™
Iowa
So it is the front springs? The way you said it made it sound like you replaced the rear springs.
Blazed
Accepting Donations
This is all terribly confusing...
Buzarr
