Suburban 2500 models
oifla
Hello all,
I'm doing some research towards my next vehicle purchase and I have a couple of 2500 specific questions.
- Are there any significant model year differences between 2001-2006 2500 Suburbans? That is, other than mileage and newness, are there any compelling reasons to choose a 2004 over a 2002 (for example)? I saw a brief mention of a wiring update (can't remember if it was here on another board) but there were no specifics.
- I only plan to tow every now and then and rarely anything above 8,000 lbs but I am going for the 2500 because I like the rear leaf suspension and the stronger transmission. As far as engine choice I'm seeing about as many 6.0L as 8.1L trucks but was leaning towards the 6.0L for the fuel savings (however marginal). In terms of reliability, are there any known problems with the 6.0L?
Thanks!
O.
fiatdale
Houstons Best
Houston
2003 got an updated interior which looks much better. 6.0L is one of the strongest motors out there, lots of power can also be gained with a tune.
adventurenali92
Big Bear Lake, ca
As @fiatdale said above, the 2003 plus interior is a lot nicer than the 2002 interior. The 2003 models also saw the addition in the upper end packages, power fold away mirrors and the power mirror are also linked to memory adjustment. Which I really like. The 2005 and 2006 models also for the electric cooling fans behind the radiator which is nice. I'd say if you're not towing any more than 8000lbs like you said the 6.0 should be a very capable motor for you and it's an extremely reliable motor.
Chuck 2015 Tahoe
