Oil pickup tube
adventurenali92
Big Bear Lake, ca
Hey fellas, I’ve searched around and can’t seem to find an answer, could someone show me the proper part number for an oil pickup tube and screen for a 2006
GMC Yukon XL with an LQ4 6.0?
I need this but can’t find the right application:
wjburken
Eastern Iowa
adventurenali92
adventurenali92
Big Bear Lake, ca
Here’s the RA page for yours but the GM one isn’t listed. However if you look at the Melling one, it lists 12563961 as an alternative part number.
The GM Parts Direct site does list your truck under compatibility for the 12563961 also.
adventurenali92
adventurenali92
Big Bear Lake, ca
I saw the rock auto listings and wasn’t sure which one to click on. Interestingly enough yesterday I did see the GM one but wasn’t sure it was right. Thanks for the heads up! I was thinking to order the melling one. Is that a good choice?
Melling is great quality. Their oil pumps are the go-to most of us buy.
That’s what I thought! Cool
Cool! Should I replace the oil pump while this is opened up to get the pickup tube out?
To replace the oil pump you need to pull the front cover and in order to do that you need to pull the harmonic balancer, radiator, etc. If you’re replacing the pickup tube because you’re replacing the o-ring then nothing else besides the pan needs to come off. I take it you’re concentrating on the o-ring and doing the pickup tube while you’re there? If so, I’d stick with that. I doubt your oil pump needs replacing. Here’s a great article that covers the oil pump among other things. Bookmark this site, it’s got great info.
Yote1
