no brake lights or 3rd brake light
brianarmstrong
I have a 2013 yukon I have no brake lights or high centre light in rear The cruze control works as it should and I can shut it off with the foot pedal The turn signals and 4 ways work fine ,I suspect the white wire from brake light switch to the turn signal switch is defective any thoughts on this
Welcome to the Forum from NH.
Pics of the truck, please.
Have you checked the fuses?
What voltage ate you getting at the brake switch output, when the brake pedal is depressed?
Fless
Super Moderator
Elev 5,280
Moved this thread here from the 2021+ section.
St. Louis
Has the light outage been confirmed while the vehicle is running and not just parked? The brake lights won't come on unless the vehicle is running
BattleBorn
