My brakes failed today and I see brake fluid leaking
BrooklynMike
Brooklyn, NY
I can't get a good look at where the leak is coming from.
I see the brake lines coming from the master cylinder and they look fine, but right under the driver's side is where the leak is dripping and all I see are wet rusty brake lines. Based on the pics/video below what do you think it could be?
https://www.dropbox.com/s/g15ofjmhpugh1vb/2014-06-22 14.38.39.jpg
https://www.dropbox.com/s/8rdlromrnfr0lvm/2014-06-22 14.38.50.jpg
https://www.dropbox.com/s/exjyadsbevlyzu5/2014-06-22 14.39.02.jpg
https://www.dropbox.com/s/br3ljxcn4tribhp/2014-06-22 14.39.05.jpg
https://www.dropbox.com/s/sd1b5b7paygezoy/2014-06-22 18.39.23.mp4
https://www.dropbox.com/s/a7j12uz4qyhbcvk/2014-06-22 18.40.00.mp4
Yesterday my friend helped me snake a power wire for my subwoofer through the rubber gromnet in the engine bay. We were pretty careful and I don't think this is related to the brake issue. The brake lines look pretty rusted so I think this is probably a coincidence. I'm going to take it to the shop 1st thing in the morning.
---------- Post added at 03:51 PM ---------- Previous post was at 03:16 PM ----------
I came across this report while doing some googling
http://www.abcactionnews.com/money/...gm-owners-report-brake-line-rust1376563067304
I think this past winter put a beating on my truck. I guess I'm learning the hard way about the importance of getting the under carriage washed. My rear brake lines went bad in December and the stealership fixed it. I wish they would have at least mentioned the problem with the brake lines going bad.
08grey
Be very carefull. Give thanks that this didn't happen on the highway.
Wake
Stafford, VA
I'm keeping a close eye on my lines as well.
I don't have it bookmarked on this computer but the NHTSA has an investigation open on brake lines on GM full size trucks and SUVs. Hold on to your receipt as you may get reimbursed for your expenses later if they force a recall.
They've had enough complaints now that they are looking into it.
Gzes
the drifting 2dr
Wichita tx
Glad it didn't happen while going fast. The north will rust out the lines
Pawaso
