motor build questions
tobysan90
My 05 suburban has 205thousand miles and is starting to make noise and smoke from the VGseals leaking. My questions is i have a 80thousand mile 6.0 block and a set of new 5.3 heads, i know they can be bolted on and run my factory intake and all that, what cam would you guys recomend for this build just as it being a tow pig and random driver.
YukonXL04
The Riverboat
Arlington, TX
you would probably get more responses posting this in the NBS performance section. however most are going to say call a cam company and tell them your plans and driving style, and they can recommend one.
tobysan90
tobysan90
ok thanks sir, just didnt want to post in wrong section and all that jazz
ccapehartusarmyINF.(ret)
Gilbert AZ
for towing id recomend running a stock cam or stock equivalent as far as lobe lift and duration and all that or a cam setup for low end power loud harly sounding deep loping cams have alot less low end power thats why a higher stall speed torque converter is recomended also for towing its a good idea to go with the 5.3 heads it will keep a lower compression ratio wich is better for towing highcompression ratios create more HP but also create more heat
Off Road Pedia
