more lift ?
preshus
preshus
washington,IN
You could put a bigger body lift on it.
You can also jack up the truck and check gear ratios by spinning the driveshaft and tires.
ya i was told that the other day jack the truck up and spin the wheels
if it goes 4 and half rotations then i got 456 gears and so on or an
easyer way to see if they even match is mark the tires front and rear
and see if they hit the same mark same time every rotation . . .
but hell i only got one jack and no wood or cement blocks at all
to cut the distance between the ground and my truck lol the jack
won't come close to it at all . . . would kill me if i got a flat on the
road lol
preshus
preshus
washington,IN
just got my truck back and i feel sky high again i guess it dose set pretty high. . .
il post piks of the light brackets in a bit
preshus
preshus
washington,IN
id do that... maybe have to trim bumper corners and hit fender edge in.
side note.. any pics on how he did the lights in diesel bumper? im about to put mine back in and need to figure a better mounting way
heres the best ones i could get . . . looks like the bumper has a lip on it
allready for the lights
preshus
preshus
washington,IN
i might be wrong tho that could be something he added for a lip if so he dam good
welder
the big blue bus
richmond, va
looks welded on almost but thanks for the pics. ligts look similar to mine but i used s10 fog lights. need to remount them *** mod em for hids soon
preshus
preshus
washington,IN
ya man good luck . . . i gota figure out all the wireing on mine to find out why they
won't come on
_Dylan_
STAY FROSTY
They look like cheapo fog lights. The bulb is probably burnt out on it.
preshus
preshus
washington,IN
checked both bulbs like comen since and theyr good . . . traced the
wireing as far as i could and it disapears can't find it any where iv ripd
the whole dash out and everything i can't find nothin
preshus
preshus
washington,IN
Maybe the fuse is popped?
naw checked that to man . . . i think that he had them wired to the
toggle switch on my dash and the guy after him unhooked the lights
and wired the train hornes to the toggle so i need to look again i guess
for a wire thats not hooked up thats gota be it but i may be wrong idk
MTN_KDA
