Light bar mounted need help with idea for switch
Bharding
New owner with my first mod
42" aux beam led light bar mounted behind the grill.
Now just needing ideas on how to power it via the wiring harness. Switch or with fogs?
Ridechevy09
South carolina
It's a crappy picture but this is where I mounted mine, but I plan on putting four more light bars on my Tahoe so instead of having five switches I'm going to put a main switch under the mounted to the side of my console. That's something to take into consideration, if your only going to mount one bar then I'd put it here, but if you plan on doing more I'd install it in a place where you can put a control box that's not in the way of things. Such as, on the side of my console image.jpeg
01Konvict
Boats n Hoes
Raleigh/SML
Get a small round rocker switch and mount it inside one of the aux power plugs below the radio
gibbygsxr
Kingston, NY
I wired mine to come on with the high beams. No holes in the dash, no wires to run in the car and no ugly switch.
fiatdale
Houstons Best
Houston
If you want it to look stock... get an overhead console from a Silverado / Sierra that has the spot for the roof light switch, then wire it into that.
804getSome
