BlaineBug
- Joined
- Dec 29, 2019
- Posts
- 1,132
- Reaction score
- 629
When I click on that link I see the following which makes me apprehensive because the HIDs and LEDs are new to me and there are so many varying opinions on retrofitting.
If you are upgrading to HIDs then there is retrofitting involved as they require a ballast. But if you are switching from halogen to LED they should be plug-and-play, no modifications necessary. Check out Lasfit, they are affordable as an entry product and should give you a good idea if you want to keep LEDS or possibly get something even better in the future.
Also Lasfit ARE sufficiently bright, as I tried another cheap brand that was dimmer which I returned before I gave Lasfit a try!
I also have Lasfit bulbs in my reverse lights, I forgot to mention, which are TREMENDOUSLY bright in comparison to the factory halogen bulbs.
On my Yukon the only light bulbs that can be removed and replaced are high beam, low beam, fog, reverse lights, and license plate lights. Everything else is factory non-replaceable LED from the factory.
