Is it the alignment?
STEELHORSE
Cleveland
I've gotten my torsion keys put on about 2 weeks ago and I've noticed it but not said much. It seems like the front wheels are not aligned correctly, like the bottoms are pushed inside more. Is this supposed to look like so or does it need realigned?
fire730
Louisiana
It needs to be aligned. When lifting the truck with torsion keys you will have positive camber (looking at the front of the truck the wheels will be like this \ /.)
STEELHORSE
STEELHORSE
Cleveland
Ok guys thanks so it should be completely straight down with NO slants at all. Do you think if I took it back they would redo the alignment for me or charge?
fire730
Louisiana
It should be pretty straight up and down.
If you adjusted or replaced the torsion keys they will probably charge you again unless you got a deal somewhere that gives lifetime alignments.
