High Speed Bumpy Ride Mystery
rgpinder
My 2001 Yukon drive smooth as silk under 60, but around 60 or 65 it gets really bumpy. Now before you ask I just put some new tires (balanced) on it, and it helped to some degree but the bumpy ride is still there. What are the 1 or 2 things that might cause this? Wheel bearings? Other?
my 03 Silverado used to be a bumpy ride, put new tires AND wheels (same size 22" wheels and exact same size tires as the old ones) rides like a Cadillac now, not saying it couldn't be other things but there is a HUGE difference on mine.
What do you mean bumpy?
Is it your road?
Different springs on the vehicle?
Shocks worn out?
Tires /wheels out of round?
Need more info here
that's what I think was probably wrong with mine "wheels not round" because different tires didn't make any difference only when I changed the wheels, the shocks are still the same ones I put on mine 5+ years ago
OneofFew
Talullah Falls, Ga
Is it your road?
Shocks worn out?
Need more info here
+1.
I'm not certain the OP is not referring to vibrations. A rough ride could be caused by high tire pressure. The faster you go, the more the suspension gets loaded, the more tire pressure effects the ride. GM suggests a certain tire pressure for ride quality, tire manufacturers list maximum allowable pressure.
JRSB16
