Help me identify these under dash connectors 99 Yukon Denali
lisach
While identifying a possible location to plug my new brake controller into a factory wiring harness plug, I want to identify these 2 under dash connectors.
Can anyone help me identify what these are for?
I would like to locate a schematic for the 1st one in case that is where my seat heat problem may be.
And if neither of these locations are where I would plug the controller into a factory plug for the wiring harness. Does anyone know where that plug would be? If in fact there is one, else I have to hard wire it in.
Electric Junction box fuse or relay box located under dash to the left side of the steering column.
Unknown single connector directly under the steering column.
Thanks in advance
L
lisach
Hey thanks Man! I really appreciate it.
I did actually figure out the little Data Link Connector. But this helps because there was no reference to this in the owner's manual, and the cover for the "Convenience" Center has always been missing, so I couldn't RTFM.
But unfortunately this doesn't solve my original quest.
The location, if any, of a "Convenience" plug-in to the wiring harness for an electric brake controller.
Too bad they didn't figure that would appropriately go with a "Convenience" Center! LOL
Do you know where it might be?
PG01
Up here to the right
Actually, my 99 tahoe came with a factory pigtail harness for the electric brake controller (one side had a terminated connector and the other was bare wires to splice to trailer brake controller) and a large fuse bundled in the console. The fuse goes into the underhood fusebox and factory pigtail plugs in under the dash on driver side. Ill try to find a pic and i think i still have the harness ...F4F5FFDA-C7FA-4739-B31C-FE571EE38C83.jpeg
Anybody can correct me here if im wrong... @east302 ;)
Laurents10
